B series compressor work with D series components.
etc. D series lines, stock components, i did a b16a1 Swap into EG.
also will my AEM pulley fit to D to B power steering?
No. A D series compressor is made by Sanden. A B series compressor is made by Nippondenso. The suction and discharge hoses are different and so is the compressor bracket. You can just bolt up your old D series compressor to your B series engine by getting a bracket from the Del Sol or CRV. I'd get the CRV bracket because it's cheaper. I don't know the part number. Maybe someone else will post it for you. In order to get the B series compressor to work, you must get a bracket from a 99-00 Si and also buy new suction and discharge hoses. This will be a lot more work than just getting the correct bracket.
camoxiong
Aug 14, 2014 01:51 PM
LilLowEK
12
Sep 17, 2012 08:51 AM
Heylookits shawn
Sep 15, 2004 04:55 AM
