help: help me name this parts on my b16a2...
hi,
i was haven a hard time Trying to find a part name on my b16a2....I know how it look like but i don't know what is it call....I need the name so i could go to the dealer and buy that part..yea that part is missing so i need that part to complete my engine...
Modified by skyvang2 at 4:16 PM 7/12/2007
I'm sure that is the knock sensor hole, if the other plug you are talking about has a rubber boot over it, thats the oil pressure switch, the knock sensor has a two pin grey plug with only one wire in it.
EDIT: You have both the oil pressure sender and the knock sensor in there, the knock sensor is right above that rubber boot plug, which is the oil pressure switch.
http://www.hondaautomotivepart...82%29
the part you need is part 2 in that link, its the PCV joint that that other really short vacuum line goes it.
Modified by slowcivic2k at 6:23 PM 7/12/2007
