Rebuilding Engine
Old Jul 12, 2007 | 11:59 AM
bitz95civ's Avatar
Default Rebuilding Engine
I burned a piston and put a hole in the cylinder wall and I was wondering what parts I would need to buy to rebuild the engine?
Old Jul 12, 2007 | 12:00 PM
Luserkid's Avatar
Default Re: Rebuilding Engine (bitz95civ)
Well either a new block or sleeves to start. Then pistons, rods, and so on.
Old Jul 12, 2007 | 12:03 PM
MDM's Avatar
MDM
Default Re: Rebuilding Engine (Luserkid)
what^^^he said.. while there just do the whole block!
Old Jul 12, 2007 | 01:47 PM
slowcivic2k's Avatar
Default Re: Rebuilding Engine (MDM)
First of all what caused the piston damage? You might have further damage inside the block.
The condition of the block needs to be verified to see if a rebuild is possible, if the walls are scored up from metal flying around, you will need sleeves. The condition of the head also needs attention to see what all hit the valves and chamber.
A complete stripping of the block, rebore, new oil pump, bearings, and oversize pistons is what I would do if the condition of the block/crank/rods are good.
Old Jul 12, 2007 | 02:09 PM
ekBlackHatch's Avatar
scrap that block and check on the performance section on ht golden eagle has some blocks on there for sale for decent prices (with GE sleaves and u chose the bore)
kazino42
Jan 7, 2009 07:58 AM
RACEPAK
May 9, 2008 03:08 PM
fknfast
Jan 25, 2006 07:19 PM
b16 matt
Sep 27, 2004 02:33 PM
LS-G
Jun 8, 2002 04:55 PM
