B20Z Opinion
Old Jul 12, 2007 | 10:58 AM
Bkholder's Avatar
Default B20Z Opinion
Quick opinionated question for anyone who knows how to upgrade honda's.
I just bought a 97 ex with a B20Z(not installed yet) i already have the ls mani, gsr ecu, axles, clutch and trani, 99 si motor mounts. Is there anything im missing. Also people are telling me to just keep it stock and boost it and some are telling me to go N/A. Any opinions// experiences thatll help. I also want this to be a reliable car as much as possible. Thanks
Old Jul 17, 2007 | 07:39 PM
b18c1ej8's Avatar
Default Re: B20Z Opinion (Bkholder)
i would deff make it obd1 and go n/a becuz of the fact the b20's have really thin cylinder walls
Old Jul 17, 2007 | 11:02 PM
DC-2uned's Avatar
Default Re: B20Z Opinion (b18c1ej8)
Tell em Mingz! b18c1ej8 is right, due to the design of the b20 block, the space between sleeves is a weak point. Many people will argue that they can withstand a substantial amount of power over stock, but if you take the amount of stories about cracked b20 sleeves vs. cracked b16/b18, you will easily see they are more prone to failure. As far as the NA vs. FI arguement goes, I really don't think it matters as long as you keep the revs under 8500 and power in the low-mid 200whp region, it should be equally reliable. I say go FI because you can't even argue hp per dollar between the two.
Edit: Just noticed this was your first post, things to remember on honda-tech 1) Always search before you ask (otherwise e-gangrape is inevitable) and 2) Get your post count up noob, because around here having a lot of posts is like being the smartest guy with the biggest d**k lol.
Hope you learned a lot.
Old Jul 18, 2007 | 09:06 AM
el3men2_4dr's Avatar
im using a b20z2 block in my car and its been good ever since its been in ran good numbers and its still runs strong i like the set up i have b20vtec n/a i made 185whp cant complain
Old Jul 19, 2007 | 08:34 AM
Trickturn's Avatar
I would trade your GSR ECU for a LS ECU. GSR will toss some codes for IAB's & VTEC.
Also, I would stay N/A & beat around w/ it.
I suggest you look @ FI another time if you really want that.
Pete
boxer71c
Jan 29, 2015 04:46 AM
redyute
Oct 30, 2012 06:03 PM
Annihilator
Apr 16, 2010 12:31 PM
tek9_ej2
Dec 9, 2008 01:36 PM
QB21
Jul 22, 2005 06:21 AM
