grinding tranny
Old Jul 12, 2007 | 06:14 AM
ekdj's Avatar
Default grinding tranny
I have a slight grind in 2nd when shifting from 1st in any rpm... i was told to change the tranny fluid... will this solve the problem and what tranny fluid do you guys recommend.
thanks
Old Jul 12, 2007 | 06:15 AM
ekdj's Avatar
Default Re: grinding tranny (ekdj)
also the tranny is a b16 w/ lsd if that helps thanks for input
Old Jul 12, 2007 | 02:36 PM
5_Lug_B's Avatar
* B A N N E D *
Id change the fluid and see if that helps. Id reccomend OEM Honda MTF or if you dont want to go with that IVe heard good things about GM Syncromesh
Old Jul 12, 2007 | 02:42 PM
Team Protocol's Avatar
it might just be the fluid or u have a tranny that just needs to be replace.. how long has this been doing this?
Old Jul 12, 2007 | 03:04 PM
slowcivic2k's Avatar
Default Re: grinding tranny (Team Protocol)
See if the shifter walks around when its in gear with your hand off of it, if it pops out of gear, ISB died, need a new one.
With the car on, push the clutch pedal all the way in, let it sit that way for 5-6 seconds, then let it out and take note of the change in pitch, or have a buddy put an ear near the bellhousing and listen for a scratching whirr type noise, if the noise is very distinct, you have a worn/failed bearing.
The second gear synchro is a double cone configuration, which has the best engagement ability of all the synchros in the transmission.
To isolate synchro failure, take the car on a drive, and shift the car into gear at various RPM points (IE goto 5000 in 1st, shift to 2nd, and take note of the feel. also do a downshift from 3rd to 2nd, and note the same thing. Then try to match the RPM's before you try to shift into that gear and see if the clash goes away, like if you shift at 4000 and you know the rpm's will drop to around 2800, keep it around 2800, and then shift into 2nd.)
If the clash is less noticable if you match rpm to that gear, most likely the synchro ring and cone is worn for 2nd, and may need to be replaced. How many miles are on that transmission, and how do you shift day to day?
10W30 oil will be fine, but I would stick to Honda MTF.
Old Jul 13, 2007 | 06:01 AM
ekdj's Avatar
Default Re: grinding tranny (slowcivic2k)
my tranny only grinds when i shift at any rpm from 1st to second but if i down shift from 3rd to second it doesnt... yesterday i replace fluid with honda mtf and it still does it... do i need my tranny rebuilt... its a new tranny from hmotors about 30,000 miles so they say
Old Jul 13, 2007 | 06:03 AM
Syndacate's Avatar
Your syncros are probably going.
Try double clutching from 1st to 2nd.
Old Jul 13, 2007 | 06:39 AM
97Ej6mike's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Your syncros are probably going.
Try double clutching from 1st to 2nd.</TD></TR></TABLE>
That is a possibility.
But also keep in mind if he has a worn clutch, that could also be it. A worn clutch wont fully disengage from the flywheel because the splines on the pressure plate are worn. Ive seen this happen with a friends single cam; when on jack stands, even with the clutch in (fully bled), the wheels would start moving in first gear.
The tranny was in fine shape, but it was only the clutch that had to be replaced. Once the clutch was replaced, the car drove normal.
Old Jul 13, 2007 | 06:42 AM
ekdj's Avatar
Default Re: (97Ej6mike)
thanks for the input... i'm gonna replace the clutch and flywheel anyway
Old Jul 13, 2007 | 06:43 AM
speedooo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
The tranny was in fine shape, but it was only the clutch that had to be replaced. Once the clutch was replaced, the car drove normal.</TD></TR></TABLE>
yeah but he can downshift from 1st to second just fine...i had this happen with my y8 trans, i couldnt go from 1st to 2nd but i could downshift from any gear to 2nd. Im not too kind to transmissions....
Old Jul 13, 2007 | 07:43 AM
97Ej6mike's Avatar
Default Re: (speedooo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo &raquo;</TD></TR><TR><TD CLASS="quote">Im not too kind to transmissions.... </TD></TR></TABLE>
That is why we both know how to swap D trannys like nobody's business
red5FWD
Jan 27, 2008 07:43 PM
b18cEF9
Jan 12, 2005 05:20 PM
FLCivic
10
Apr 14, 2004 07:19 PM
JDM-Vic
Apr 6, 2004 01:48 PM
metal-x
Sep 13, 2002 09:47 AM
