speedometer moves/car doesnt. Transmission/clutch problem please help
Old Jul 12, 2007 | 05:53 AM
cjk95delsolsi's Avatar
Default speedometer moves/car doesnt. Transmission/clutch problem please help
Here is the problem. 95 del sol si. Pulled out my tranny to replace the thowout bearing release fork (it was cracked). I have a stage 3 clutchmasters clutch and clutchmasters flywheel with 25k on them. Replaced the clutch master cylinder and slave cylinder. Now upon completing the job. I put my car in reverse and gave it gas, the speedometer increased in speed but the car didnt move. I put the car in 1st gear and gave it gas, the speedometer increased in speed but the car didnt move. Put the car in neutral and gave it gas and the same thing happened. With the car in neutral at idle the speedometer reads 5 mph, press in the clutch and speedometer goes to 0. With the engine off, any gear i put the car in I can still push the car like it is in neutral. I have though about this alot. Came up with a few ideas. I dont just want to pull the tranny out until I can narrow it down. I live in Germany and cant just go to the parts store, i have to order online. Any ideas will help.
Old Jul 12, 2007 | 06:39 AM
auto-accessories-inc.'s Avatar
* B A N N E D *
Default Re: speedometer moves/car doesnt. Transmission/clutch problem please help (cjk95delsolsi)
Make sure your axles are all the way in i had the same issue in my eg
Old Jul 12, 2007 | 06:48 AM
speedooo's Avatar
Default Re: speedometer moves/car doesnt. Transmission/clutch problem please help (auto-accessories-inc.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by auto-accessories-inc. &raquo;</TD></TR><TR><TD CLASS="quote">Make sure your axles are all the way in i had the same issue in my eg</TD></TR></TABLE>
i hate that, i had to change an axle seal and was in a rush, popped the axle in and took off, turns out it wasnt in all the way, i hit a pothole and it popped out int eh middle of highwaymerger
Old Jul 12, 2007 | 10:05 AM
axles are locked in. bump for any other ideas
Old Jul 12, 2007 | 11:51 AM
robfrmny21's Avatar
when u put it in nuetral is the car in the air and it shows 5mph or on the ground showing 5mph
Old Jul 12, 2007 | 12:03 PM
heretolearnandteach's Avatar
I can 100% guarantee you its your axles.
Old Jul 12, 2007 | 12:53 PM
EX-T's Avatar
Default Re: (cjk95delsolsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjk95delsolsi &raquo;</TD></TR><TR><TD CLASS="quote">axles are locked in. bump for any other ideas</TD></TR></TABLE>
Did you go check or are you assuming that they are in?
I had a similar problem where my clutch wouldn't engage and turned out, my passenger axle wasn't all the way in.
Old Jul 12, 2007 | 01:20 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (robfrmny21)
well, your diff is turning, either exploded the side gears or axle is not locked in.
Old Jul 12, 2007 | 01:23 PM
love of the sol's Avatar
CHECK your axles dont just guess.
Old Jul 12, 2007 | 06:16 PM
Default Re: (heretolearnandteach)
the car is on the ground reading 5mph when in neutral.
Old Jul 12, 2007 | 06:20 PM
One other idea is the possibility that the splines on the mainshaft of the transmission didnt line up correctly with the clutch and ate the teeth up on the clutch. Bump for any other ideas because when pull the tranny out again I want to have all of the possible damaged parts on hand and ready to put in.
Old Jul 12, 2007 | 07:24 PM
n1_egsex's Avatar
* B A N N E D *
axles, i had the same problem on one side, it wasn't seated all the way in
Old Jul 13, 2007 | 05:38 PM
Mista Bone's Avatar
D Tranny Guru
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjk95delsolsi &raquo;</TD></TR><TR><TD CLASS="quote">One other idea is the possibility that the splines on the mainshaft of the transmission didnt line up correctly with the clutch and ate the teeth up on the clutch. Bump for any other ideas because when pull the tranny out again I want to have all of the possible damaged parts on hand and ready to put in.</TD></TR></TABLE>
then the speedo wouldn't be moving, it's your axles.
Old Jul 13, 2007 | 07:16 PM
Crx Jimmy's Avatar
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">
then the speedo wouldn't be moving, it's your axles.</TD></TR></TABLE>
really, check your axles. If your speedo is moving your diff is turning.
Old Jul 15, 2007 | 02:19 AM
Mista Bone's Avatar
D Tranny Guru
$1 bet he seperated a joint at some point during the clutch change.
Old Jul 15, 2007 | 10:22 AM
It was the axles, weird. They locked in when I installed them. They must have popped out when I torqued the axle nut. Thanks for the help.
Old Jul 15, 2007 | 06:33 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">$1 bet he seperated a joint at some point during the clutch change.</TD></TR></TABLE> $2
Old Jul 16, 2007 | 01:25 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (auto-accessories-inc.)
you doubling up my bet?
Free Beer in PA!
Devers
Transmission & Drivetrain
Nov 10, 2011 08:42 PM
Devers
Oct 31, 2011 04:55 PM
phoshyzzle
Mar 23, 2009 03:20 PM
teg969
Jul 21, 2008 01:07 PM
cleancord
Oct 3, 2006 11:15 PM
