has anyone ever heard of a low compression head gasket
i heard tha u can buy a head gasket that lowers your compression is there such head gasket like if so where can i buy one
who is king did u know any links that could show it that way i could google because i tried to google low compression head gasket but no luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sick CD7 »</TD></TR><TR><TD CLASS="quote">yes its a thicker head gasket forget where but i think king had them awhile back </TD></TR></TABLE>
Yeah, thicker headgasket = lower compression, thinner = higher compression. Lowering the top of the head lowers the volume above the cylinder (raising compression) - that's why some people mill the head down, but be weary of where the cylinder head ends
A lot of people take the Y8 stock 3 layer headgasket and pull the middle layer out to make it thinner, they pick up some compression that way.
What type of motor do you have?
.A lot of people take the Y8 stock 3 layer headgasket and pull the middle layer out to make it thinner, they pick up some compression that way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan_JDM_hatch »</TD></TR><TR><TD CLASS="quote">who is king did u know any links that could show it that way i could google because i tried to google low compression head gasket but no luck </TD></TR></TABLE>
There's a good compression ratio calculator but it's down right now.
D Series Compression Ratio Calculator
B Series Compression Ratio Calculator
Play with the headgaskets there - sorry if that B series doesn't work, the site is down right now ;crook:.
look i have a b18b1 turbo on a hatch the rings are going bad so i wanted to reaplace the rings but im going to ls vtec i know i will have more compression than a gsr motor
so i knowi need to lower the compression on it i cant buy low compressions pistons yet
i dont have the money yet but i have enought money to do ls vtec and rings but i want to lower the compression
Modified by Ivan_JDM_hatch at 12:36 AM 7/12/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan_JDM_hatch »</TD></TR><TR><TD CLASS="quote">none of those link works</TD></TR></TABLE>
Yeah, the site is usually up - but now the site is down, give it some time.
b18, civic, compresion, compression, gasket, h22, head, headgasket, honda, low, lower, lowering, ratio, series, thicker
