Mysteriously losing coolant
Old Jul 11, 2007 | 08:33 PM
Khmi's Avatar
Default Mysteriously losing coolant
I have a been losing coolant at a pretty steady rate for the past month or so, about 1/4 cup of coolant out of the reservoir for every 100 miles of driving. I cant find any place that its leaking from. I did a did a radiator pressure test, and it lost about 1 psi of pressure in about 15 min but never dropped anymore after that. The car is running strong and the oil/coolant is not milky. Any ideas?
Old Jul 11, 2007 | 08:58 PM
Tippyman's Avatar
Default Re: Mysteriously losing coolant (Khmi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Khmi &raquo;</TD></TR><TR><TD CLASS="quote">I have a been losing coolant at a pretty steady rate for the past month or so, about 1/4 cup of coolant out of the reservoir for every 100 miles of driving. I cant find any place that its leaking from. I did a did a radiator pressure test, and it lost about 1 psi of pressure in about 15 min but never dropped anymore after that. The car is running strong and the oil/coolant is not milky. Any ideas?</TD></TR></TABLE>
Sounds like the car is either burning it or you have a small leak somewhere. When you say you did a pressure test, did you only test the radiator or the whole coolant system?
I had a small coolant leak and couldn't figure it out either. Turns out the my clutch cable bracket rubbed the hose just a tiny bit and it was dripping out. I couldn't see it at all, but it dripped really slow.
Old Jul 11, 2007 | 09:13 PM
Khmi's Avatar
Default Re: Mysteriously losing coolant (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
My friend did it for me. He took off the cap and attached it to the neck where the cap was, and pumped it up to pressure it.
Old Jul 11, 2007 | 09:20 PM
Tippyman's Avatar
Well, when the car is cold, the thermostat is closed, so maybe the leak is behind the thermostat?
Old Jul 11, 2007 | 09:34 PM
Khmi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Well, when the car is cold, the thermostat is closed, so maybe the leak is behind the thermostat?</TD></TR></TABLE>
maybe, but i left the car idling for 20 minutes still don't see a leak, but might be very small i got to feel around a bit more.
Old Jul 11, 2007 | 10:01 PM
Tippyman's Avatar
maybe, but i left the car idling for 20 minutes still don't see a leak, but might be very small i got to feel around a bit more. </TD></TR></TABLE>
Leaks are much more prominent when the engine is under load, BTW.
Old Jul 12, 2007 | 10:22 AM
cars101's Avatar
when i first got my rex, it was leaking out alot but when we looked under the hood we didnt see anything but wetness. when i started the car and waited and then got frustrated i turned it off and thats when it would leak out a little bit of a couple broken hoses.
Old Jul 12, 2007 | 10:29 AM
IT GUY's Avatar
I had a small coolant leak and couldn't figure it out either. Turns out the my clutch cable bracket rubbed the hose just a tiny bit and it was dripping out. I couldn't see it at all, but it dripped really slow.</TD></TR></TABLE>
that was you with the leaky clutch cable? lol
T9U4ReBgO
Feb 22, 2008 04:44 PM
korean_teg
Sep 29, 2005 07:00 PM
97akwerd
Jul 30, 2005 08:43 AM
Motts
May 25, 2005 05:16 PM
N1NjA TuRtLE
11
Sep 11, 2003 10:36 AM
