Weird Idle Problem
I'm running B series boosted but my car wont idle for anything I have to stay on the gas for the motor to stay on. At first I thought it might be the plugs so I changed them out but its still doing it. THen I figured boost leak but nothing was loose. I checked all vaccuum hoses and none were ripped. After a while I took off the vaccuum line on the fuel pressure regulator, BOV, and wastegate and now the car idles perfect. What the hell is that about? Anyone have any clue? Its like the engine cant breath and when i disconnect the vaccuum lines it starts to breatheeee lol. HELP ME OUTTT!!!
Set-up is:
T3 turbo
38mm wastegate
HKS bov
2.5 bar motorola map sensor
basemap from phearable.net
Set-up is:
T3 turbo
38mm wastegate
HKS bov
Is your map sensor wired up properly ?
Do you have a wideband ? If not you really should get one
Pm me with your first & last name, perhapse you mis-typed your injector size on your order or forgot to indicate a 2.5 bar ?
Regardless, I would like to help you figure it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drshottest718 »</TD></TR><TR><TD CLASS="quote">pmed. anyone have any ideas?</TD></TR></TABLE>
I looked over your basemap, everything looks to be normal from what I can see.
What impedance injectors are you running ?
If your running low impedance injectors you should be running a resistor box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drshottest718 »</TD></TR><TR><TD CLASS="quote">bumpppp....all wiring is right...its gotta be something else</TD></TR></TABLE>
Issue figured out.
Appears basemap was ordered/made for 550cc injectors instead of 440cc injectors
Issue figured out.
devonic
Jul 11, 2003 10:46 PM
