is 1100 worth about 20 hp????
Old Jul 11, 2007 | 05:42 PM
pchan's Avatar
Default is 1100 worth about 20 hp????
this is for a b16.. im installing bc3 cams springs and retainers and cam gears for 500 bucks.. i spent about 550 for the parts all together close to 600.. is it worth it??i should of built a turbo kit.. huh?
Old Jul 11, 2007 | 05:43 PM
ke98248's Avatar
Default Re: is 1100 worth about 20 hp???? (pchan)
umm, hell no!
Turbo FTW definately!
Old Jul 11, 2007 | 05:49 PM
Luserkid's Avatar
Default Re: is 1100 worth about 20 hp???? (ke98248)
I wouldnt run the BC3's on stock bottom end. I think you need 11.5 c/r for those. NA power is way different from turbo. But you wont find a good reliable kit for 1100 unless you know someone.
Old Jul 11, 2007 | 05:54 PM
slowcivic2k's Avatar
Default Re: is 1100 worth about 20 hp???? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt run the BC3's on stock bottom end. I think you need 11.5 c/r for those. NA power is way different from turbo. But you wont find a good reliable kit for 1100 unless you know someone. </TD></TR></TABLE>
http://www.trackspeedracing.co...-CAMS
made 206whp with a mostly stock B16A with 11.4:1 compression, OEM parts, a slight mill and flat valves.
Cams used were the early grind (smaller) M22's
Old Jul 11, 2007 | 08:37 PM
pchan's Avatar
should i use a thinner head gasket than the oem ones or should i just leave it oem... i dont have cash now to upgrade valves or pistons..
Old Jul 11, 2007 | 08:41 PM
JALOP B16's Avatar
Turbo
Old Jul 11, 2007 | 08:51 PM
pchan's Avatar
Default Re: is 1100 worth about 20 hp???? (JALOP B16)
too late for turbo now.. i told the mechanic to just install the cams and use a honda head gasket... what else could i do now?
Old Jul 11, 2007 | 09:31 PM
CooBlueDAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pchan &raquo;</TD></TR><TR><TD CLASS="quote">too late for turbo now.. i told the mechanic to just install the cams and use a honda head gasket... what else could i do now?</TD></TR></TABLE>
I would have gone thinner with the head gasket, but since you did that, you now need a real tune on a dyno... If you really are looking for something to do.
Old Jul 11, 2007 | 10:03 PM
pchan's Avatar
Default Re: is 1100 worth about 20 hp???? (CooBlueDAB)
what head gasket then.. i have until 8 in the morning to get a head gasket and it is 1102 pm now.. what do you recommend?
Old Jul 11, 2007 | 10:07 PM
HondaIsTehGay's Avatar
i would rather have a doughnut broooo. i hate all this ****
Old Jul 11, 2007 | 10:09 PM
motor_man's Avatar
Default Re: is 1100 worth about 20 hp???? (HondaIsTehGay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaIsTehGay &raquo;</TD></TR><TR><TD CLASS="quote">i would rather have a doughnut broooo. i hate all this ****</TD></TR></TABLE> what?????
Old Jul 11, 2007 | 10:22 PM
CooBlueDAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pchan &raquo;</TD></TR><TR><TD CLASS="quote">what head gasket then.. i have until 8 in the morning to get a head gasket and it is 1102 pm now.. what do you recommend?</TD></TR></TABLE>
I have read using 2 of the OEM or a thinner one. However it is much later for me and I am not thinking straight. Search the N/A Forums for the engine and head gaskets, you will find the answers. However I know just 1 gasket has issues... I just do not remember which.
bjizzle07
Honda Civic (2006 - 2015)
26
Apr 3, 2012 03:14 PM
jw15u
Oct 6, 2009 01:39 AM
honda_user
19
Jun 5, 2005 04:32 PM
badasshatchhh
May 16, 2005 05:26 PM
JDM00SI
Mar 23, 2005 01:10 PM
