36 mm hub help
Old Jul 11, 2007 | 03:40 PM
pogeeboy27's Avatar
Default 36 mm hub help
Sup guys. I'm replacing my 32 mm hubs with 36 mm CRV hubs. The question I have is what bearings do I use? I bought the CRV bearings and they are too big to fit the knuckle. I think Prelude bearings would fit with the 36 mm hubs but I just want someone to confirm this for me. Thanks for your help.
Old Jul 11, 2007 | 06:43 PM
migs's Avatar
Default Re: 36 mm hub help (pogeeboy27)
What US bearing will accomodate a 36mm hub on an EG/DC? The outside diameter is larger on an Accord/Prelude/CRV bearing. It will not fit into an EG/DC knuckle.
Why not just use the 32mm hubs?
Old Jul 11, 2007 | 06:51 PM
pogeeboy27's Avatar
Default Re: 36 mm hub help (migs)
I swapped a K20 into my ITR and I hate to deal with changing the outer joints on the axles to fit the 32 mm hub. So I figured I would change the hubs to 36 mm and use RSX axles instead of hybrid axles. So my next question is, would the CRV knuckle fit on the DC2 chassis?
Old Jul 11, 2007 | 06:58 PM
cltitus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogeeboy27 &raquo;</TD></TR><TR><TD CLASS="quote">I swapped a K20 into my ITR and I hate to deal with changing the outer joints on the axles to fit the 32 mm hub. So I figured I would change the hubs to 36 mm and use RSX axles instead of hybrid axles. So my next question is, would the CRV knuckle fit on the DC2 chassis?</TD></TR></TABLE>
hybrid axles do the job.
Old Jul 11, 2007 | 07:40 PM
pogeeboy27's Avatar
Default Re: 36 mm hub help (cltitus)
Yes they do the job but I would rather have straight RSX axles.
Old Jul 11, 2007 | 09:57 PM
omiehomie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogeeboy27 &raquo;</TD></TR><TR><TD CLASS="quote">Sup guys. I'm replacing my 32 mm hubs with 36 mm CRV hubs. The question I have is what bearings do I use? I bought the CRV bearings and they are too big to fit the knuckle. I think Prelude bearings would fit with the 36 mm hubs but I just want someone to confirm this for me. Thanks for your help.</TD></TR></TABLE>
ok keep going.....
yes...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogeeboy27 &raquo;</TD></TR><TR><TD CLASS="quote">Yes they do the job but I would rather have straight RSX axles. </TD></TR></TABLE>
hmmm sounds like you need to visit http://www.k20a.org and the search button there is your friend
Old Jul 12, 2007 | 08:03 PM
pogeeboy27's Avatar
Old Jul 14, 2007 | 07:56 AM
DOMKID's Avatar
http://www.pocketrocketsracing....html
Old Jul 14, 2007 | 09:56 PM
Ill's Avatar
Ill
Default Re: 36 mm hub help (DOMKID)
D@mn those look yummy.
But they're not 5 lug?
Old Jul 15, 2007 | 10:36 AM
pogeeboy27's Avatar
Default Re: 36 mm hub help (Ill)
Thanks for the help guys. Yeah I would've hopped on those in a heartbeat but they're not 5 lug. Well the hubs are off to the the machine shop. I'll keep you posted.
Old Jul 15, 2007 | 05:17 PM
NA425DragSter's Avatar
* B A N N E D *
use cr-v knuckle they will fit on dc....use 36mm rsx axles just swap the inner joints on the 2 rsx axles...that wat i had to do on my friends k swap into a ek but we used ep3 axles... but works fine
Old Jul 15, 2007 | 06:49 PM
EleanoR's Avatar
Default Re: (NA916DragSter)
I have the JDM 36mm axles on my EG race car. I installed ARP wheel studs, lower ball joints, and the wheel bearings in the front this past weekend. I used the bearings from the CR-V. I thought the 32mm regular type R bearings would work but they did not (too small). Contact Clayton @ King Motorsports and he can hook you up.
Old Jul 19, 2007 | 02:47 PM
pogeeboy27's Avatar
The machine shop was able to make the 36 mm hubs fit the USDM knuckle. So for those of you interested, that would be one way to do it.
Old Jul 23, 2007 | 06:59 PM
pogeeboy27's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA916DragSter &raquo;</TD></TR><TR><TD CLASS="quote">use cr-v knuckle they will fit on dc....use 36mm rsx axles just swap the inner joints on the 2 rsx axles...that wat i had to do on my friends k swap into a ek but we used ep3 axles... but works fine</TD></TR></TABLE>
Would you happen to know if the ITR brakes would fit on the CR-V knuckle or did you use the CR-V brakes? If you used the CR-V brakes, will the stock ITR rims be able to clear the brakes?
Old Jul 23, 2007 | 07:13 PM
* B A N N E D *
everything is 36mm itr specs
Old Jul 23, 2007 | 07:20 PM
pogeeboy27's Avatar
So that means you have to use the CRV brakes?
Old Jul 23, 2007 | 07:57 PM
* B A N N E D *
no u can use itr breaks.
Old Jul 23, 2007 | 09:11 PM
pogeeboy27's Avatar
Thanks!
Old Jul 25, 2007 | 08:13 AM
pogeeboy27's Avatar
Thanks!
Old Jul 25, 2007 | 08:57 AM
* B A N N E D *
workd out for you?
seek167
May 16, 2006 07:39 PM
Turbocivic94
Mar 25, 2006 05:26 AM
BillB
Nov 15, 2003 06:00 AM
pennies_hatchie
12
Oct 10, 2002 12:28 PM
carsaregood
Apr 23, 2002 06:28 AM
