knock when turning
Old Jul 11, 2007 | 11:59 AM
D16Z6racing's Avatar
Default knock when turning
90 CRX DX
Knocking when I turn both ways. My roommate just had one axle replaced, but I don't know which. The car just got dumped on me and have no contact to them.
It knocks louder when turning right. Driver side axle?
Old Jul 11, 2007 | 12:01 PM
slow96coupe's Avatar
does it jump or anything while turning?
Old Jul 11, 2007 | 12:08 PM
Default Re: (slow96coupe)
no jumping.
only knocks in turns when the gas is being applied.
when going straight it's pretty loud like bad bearings.
Old Jul 11, 2007 | 04:13 PM
msinsky14's Avatar
Default Re: (D16Z6racing)
axles are bad
Old Jul 11, 2007 | 05:00 PM
fireant's Avatar
Default Re: (msinsky14)
Roll down the windows and go to a parking lot at night and you'll figure out which one is knocking.
Old Jul 11, 2007 | 08:51 PM
EFHATCHMAN's Avatar
Default Re: (fireant)
X2... either one or both of the axles are bad...The parking lot idea isnt a bad idea either... just to be sure which one it is.
Good luck!
Old Jul 12, 2007 | 01:50 PM
Default Re: (EFHATCHMAN)
I used the P&R lot before my bus came today. Driver side is noisy.
Thanks guys.
Old Jul 12, 2007 | 03:19 PM
95f22a1's Avatar
mine is doing the same exact thing! and i replaced both my axles and it still does it.
Old Jul 12, 2007 | 06:15 PM
EFHATCHMAN's Avatar
Default Re: (95f22a1)
You should check out your wheel bearings then... let us know what you find!
Good luck!
Old Jul 15, 2007 | 04:27 AM
o VALTER o's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95f22a1 &raquo;</TD></TR><TR><TD CLASS="quote">mine is doing the same exact thing! and i replaced both my axles and it still does it.</TD></TR></TABLE>
Mine too, i had them changed, and i still get a knock/click only when I turn, no noise when i drive straight.
Old Jul 15, 2007 | 08:15 AM
msinsky14's Avatar
Default Re: (o VALTER o)
yea might be ur wheel bearings. press in some new ones
Old Jul 15, 2007 | 08:23 AM
Chris Carrabba's Avatar
Sounds like you need to check out the axles and the wheel bearings. Let us know when you find out.
Old Jul 15, 2007 | 08:52 AM
95f22a1's Avatar
crx's don't like 5k rpm for very long. hahaha my axles snaped in half like when i first got my car!
Old Jul 15, 2007 | 11:50 AM
itsjusj0hn's Avatar
Default Re: knock when turning (D16Z6racing)
that sucks. had the same problem, but an axle replacement fixed the problem.
Old Jul 15, 2007 | 08:42 PM
schwinnrex's Avatar
is there a chance that this can lead to a further devastating problem? or is it just an annoyance?
Old Jul 15, 2007 | 09:00 PM
Reelizmpro's Avatar
Default Re: knock when turning (schwinnrex)
I have a knocking sound whenever I make a left turn. I've replaced everything (bearings, axles, upper/lower ball joints, tie rods, rack end bushing) and it's still there. I'm thinking it might be a motor mount or exhaust moving around.
Old Jul 15, 2007 | 10:16 PM
95f22a1's Avatar
well both my cv axles snapped in half about an hour ago i just got back to the house!!!! what a fu***n night!!!
nonvtec92
16
Mar 23, 2007 01:28 PM
Supa_Slow_Civic
Oct 16, 2005 05:46 AM
HmgLauj69
Jan 4, 2005 10:29 PM
crxste
Jun 19, 2003 03:20 PM
wusta515
Oct 16, 2001 02:08 PM
