Big Turbo Setup/LS/Vtec Jun, Hondata S300, tuned setup, NY
Yup, everything under my hood is for sale. All the turbo parts and bolt ons have about 2k miles or less on them. Everything is 100% functional and never gave me any issues. This motor was street tuned by me and is making somewhere between 400 and 430whp on 14.7 psi on a very safe tune. Motor is healthy, no smoke or any signs of giving up. I was gonna take it to 500whp but I never got a chance to. Compression test is perfect. If you sit there and start adding up how much everything cost me it comes out to over $10k. I'll trade for a car worth $6500 or take $6500 cash. I am in NY.
I WILL START PARTING OUT IN 2 WEEKS!! PLEASE DON'T PM ME ABOUT PRICES ON DIFFERENT PARTS YET! IN 2 WEEKS ILL MAKE ANOTHER POST WITH SEPARATE PRICING.
Precision SC63 Turbo P trim back wheel/ S cover w/ no problems. Capable of 700 hp
Peakboost Ramhorn Turbo Manifold w/lifetime warranty
Tial 38mm Wastegate
Heat wrapped and thermal painted intercooler piping
Tial 50mm Blow off Valve
Precision 750hp intercooler
Silicone couplers/Turbonetics T bolt clamps
Fast-Turbo Oil Line Kit
JG Edelbrock intake manifold
RPM services 76mm throttle body
LS/Vtec motor
GSR Head- brand new OEM valves and seals. 3 angle valve job. JUN springs and retainers, stock GSR cams/gears. comes with blue valve cover with welded -12 fittings for a breather system and -12 90 degree swivels. MSD spark plug wires, GSR obd2 dizzy.
MSD HVC external coil w/ MSD cap
Stock JDM LS Block B18B- no smoke, compression test perfect
ARP Headstuds
Golden Eagle LS/VTEC Kit w/ oil filter adapter
JDM CTR tranny w/ 4.7 final drive, type-r LSD
Jim-Fab Traction Bar Setup
Exedy flywheel/pressure plate w/ custom 4 puck clutch-fresh, no slipping.
Inline Pro black fuel rail
RC 1000cc injectors
Hondata s300 w/AEM boost solenoid
Aeromotive fuel pressure regulator w/gauge
GM 3 Bar Map Sensor
__________________
Modified by building boost at 8:02 PM 7/11/2007
Tial 38mm Wastegate
LS/Vtec motor
ARP Headstuds
RC 1000cc injectors
GM 3 Bar Map Sensor
__________________
mtlmotorsport
Nov 9, 2008 11:28 PM
building boost
Jul 15, 2007 03:51 PM
RyanAutry
Dec 15, 2004 08:59 AM
