ramhorn pipe size?
Old Jul 11, 2007 | 08:33 AM
got wide's Avatar
Default ramhorn pipe size?
im about to attempt my first mani and see a lot of people getting there weld els from mcmaster but the only sizes i see in 1.5"sch 40 are 1.5 and 2.5" length wich to me looks like too small of a diameter for a ram horn.
can some one please correct me if im wrong and/or give me the right size and where to buy. (i have searched thats why im asking for help)
oh and since this is my first attempt im sticking with mild steel and i have a bmc race b series premium flange machined for 1.5" sch 40
Old Jul 11, 2007 | 06:02 PM
TurboSI56's Avatar
Default Re: ramhorn pipe size? (got wide)
go to acestainless.com and buy 1.5'' sch 10 stainless
Old Jul 12, 2007 | 08:26 AM
got wide's Avatar
as per my first post, im looking for MILD steel and i know people are always recomending mcmaster i just need the bend radius size confirmed, cuz the picture of what they have looks too small.
if i went with tubing instead, what size o.d. would i need to match the same od of 1.5" sch 40 pipe? and what wall thickness would be recomended?
Old Jul 12, 2007 | 01:44 PM
AceRaceParts's Avatar
Default Re: ramhorn pipe size? (TurboSI56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSI56 &raquo;</TD></TR><TR><TD CLASS="quote">go to acestainless.com and buy 1.5'' sch 10 stainless </TD></TR></TABLE>
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by got wide &raquo;</TD></TR><TR><TD CLASS="quote">as per my first post, im looking for MILD steel and i know people are always recomending mcmaster i just need the bend radius size confirmed, cuz the picture of what they have looks too small.</TD></TR></TABLE>
There are two types of 90° pipe size elbows available today. There are the standard "long radius" and then the much more expensive and harder to come by "short radius". Most likely the standard long radius will work fine for your application.
<U>Dimensions</u>
1.5" sch40 long radius 90° elbow:
1.9" OD x .145" wall thickness
Centerline Radius/Height: 2.250"
1.5" sch40 short radius 90° elbow:
Centerline Radius/Height: 1.5"
Hope this helps a bit,
Richard @ Ace Stainless
Old Jul 16, 2007 | 08:55 AM
got wide's Avatar
Default Re: ramhorn pipe size? (R i c h)
ok well i bought 4 of the long radius in mild to test out so if they work ill be back to get more. oh do you guys give h-t discounts i thought i read somewhere that you did?
thanks for the help, joel
Old Jul 18, 2007 | 08:24 AM
got wide's Avatar
what is the wall thickness of 1.5" sch 10? and does anyone make/sell mild steel 90's in sch 10
Old Jul 18, 2007 | 09:13 AM
RC000E's Avatar
stick welding the mani....please do post pics when done
Old Jul 18, 2007 | 03:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by got wide &raquo;</TD></TR><TR><TD CLASS="quote">what is the wall thickness of 1.5" sch 10? and does anyone make/sell mild steel 90's in sch 10</TD></TR></TABLE>
.109" thick
Sch10 in mild steel is available, however it is a "taper bore" sch10 and not a true sch10 like what's available in stainless. They are expensive and not worth it, IMO.
Old Jul 19, 2007 | 08:27 AM
got wide's Avatar
what is the tapered bore? is it just like a sch 40 thats been milled down on the ends?
ralph11sec
Jan 2, 2009 05:48 AM
Evile140
Welding / Fabrication
Mar 28, 2008 06:24 PM
Ludman95
Mar 29, 2006 11:40 AM
fastcivicboy
Feb 18, 2005 08:19 AM
ThaOnlyStunna03
14
Nov 18, 2004 03:38 PM
