00si --> 96ls converter harness
I can make that for you but why would you want to run the '00 Si ECU. That ECU is not a good ECU if you want to go fast.
I would recommend switching to OBD1 and running a chipped P28 if you have a DOHC VTEC B-series swap in your '96 LS.
Email me at kenji211@tampabay.rr.com
Since you are local it will be easy to pick it up. I am in Tampa also.
-kenji
-kenji
http://jdmfan.com/technical/performance/obd2-to-obd1/
you can try that out..but i would go with a OBD1 ECU...either GSR or chipped P28
hope that helps..good luck
would it be possible to make a harness adapter for a 96 ex harness to a 00' si ecu? I just did the swap and found that one of the plugs doesnt come from the engine on the si motor.. so my car is still just sitting there
jorgejam2001
Sep 25, 2009 08:47 AM
sevenfc
Jul 23, 2009 05:57 PM
SkRiBLaH
12
Jun 23, 2006 05:43 PM
JDM99Hatch
Jun 22, 2005 02:38 PM
