need help with bearings
Old Jul 11, 2007 | 12:13 AM
turboekcivic's Avatar
Default need help with bearings
ive micrometer my d16y7 crank and the inside of my eagle rods and these are the numbers i got. i was wondering what bearing i need. i will be using OEM honda and i need to find out asap so i can finish my build.. HELP ME PLEASE
Old Jul 11, 2007 | 04:23 AM
mmuller's Avatar
Mad Scientist
Default Re: need help with bearings (turboekcivic)
now you need to measure ID of the torqued rods and mains. then you do crank OD minus rod/mains ID. then you can look at this chart
Main Bearing thickness by color
Blue 2.013-2.010 mm 0.0793”- 0.0791”
Black 2.010-2.007 mm 0.0791”- 0.0790”
Brown 2.007-2.004 mm 0.0790”- 0.0789”
Green 2.004-2.001 mm 0.0789”- 0.0788”
Yellow 2.001-1.998 mm 0.0788”- 0.0787”
Pink 1.998-1.995 mm 0.0787”- 0.0785”
Red 1.995-1.992 mm 0.0785”- 0.0783”
Rod bearing thickness by color
Blue 1.510-1.507 mm 0.0594”- 0.0593”
Black 1.507-1.504 mm 0.0593”- 0.0592”
Brown 1.504-1.501 mm 0.0592”- 0.0591”
Green 1.501-1.498 mm 0.0591”- 0.0590”
Yellow 1.498-1.495 mm 0.0590”- 0.0589”
Pink 1.495-1.492 mm 0.0589”- 0.0587”
Red 1.492-1.489 mm 0.0587”- 0.0586”
then you substract the previous total minus x2 of the bearing you want to use, whats left is clearance
and you have to use a micrometer thats goes to .0001 or lower
Old Jul 11, 2007 | 11:25 AM
methos713's Avatar
Default Re: need help with bearings (mmuller)
doesn't he need to look for lettering codes on the block to see what color bearings he's going to use?
Old Jul 11, 2007 | 02:47 PM
BILLETGRIP's Avatar
Default Re: need help with bearings (methos713)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 &raquo;</TD></TR><TR><TD CLASS="quote">doesn't he need to look for lettering codes on the block to see what color bearings he's going to use?</TD></TR></TABLE>
he would if he was using the stock rods but hes using eagle rods
Old Jul 11, 2007 | 05:39 PM
93supercoupe's Avatar
Default Re: need help with bearings (BILLETGRIP)
is this confirmed?
Id like someone else to see if this is true, sounds good to me
Old Jul 11, 2007 | 06:58 PM
BILLETGRIP's Avatar
The way i figured it there isnt an oem bearing thin enough.
Old Jul 12, 2007 | 12:07 AM
i did that but those are the numbers i got..
hondamn1320
35
Mar 25, 2010 02:04 PM
tegracer19
May 30, 2007 09:27 PM
crexer
Apr 12, 2007 01:05 PM
siis2fast
Jun 23, 2005 10:29 AM
faSHOwidIT
Jan 30, 2005 09:22 PM
