new red b series valve cover turning into crap
Old Jul 10, 2007 | 10:09 PM
moz92's Avatar
Default new red b series valve cover turning into crap
whats up guys i got new oem red type r valve cover and the grommets. i thought the rubber grommets on the valve cover were good but apparently the werent. i even torque them to spec and oil seeped out on to my new valve. is there something i could use to clean my new valve cover with out changing the color of the new red wrinkle finish
Old Jul 10, 2007 | 10:31 PM
Formula's Avatar
Default Re: new red b series valve cover turning into crap (moz92)
I used WD-40 on a clean shop rag on my ITR vc to get some of the light oil stains off of it and it worked pretty good without taking any of the paint off.
You could also try using a light degreaser.
Old Jul 11, 2007 | 09:50 AM
moz92's Avatar
cool thanx man i was getting worried . i spent almost two bills on it only to have it ruined.
Old Jul 11, 2007 | 11:04 AM
burnitdown's Avatar
try some simple green. i use it for everything
Old Jul 11, 2007 | 11:43 AM
fmrprojects's Avatar
Default Re: (burnitdown)
iono how you are leaking with new grommets. just do it hand tight really dont need to torque them.
Old Jul 11, 2007 | 11:46 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnitdown &raquo;</TD></TR><TR><TD CLASS="quote">try some simple green. i use it for everything</TD></TR></TABLE>
Simple Green works wonders, I use it for all my engine cleaning needs.
Old Jul 11, 2007 | 09:53 PM
moz92's Avatar
won't simple green make the red come off or change the color?
Old Jul 12, 2007 | 04:20 AM
MurdersV8s's Avatar
Default Re: (moz92)
Not if you do it right.
1) Spray bay down while car is off and cool.
2) Wait ten minutes.
3) Pressure wash and reapply.
4) Wait ten more minutes then wipe off with a towel.
I did this and my vc looks brand new along with my bay.
hondintegchic
Jan 21, 2008 09:52 PM
Pr0ject93hb
Jan 18, 2007 01:32 PM
jbiel
Jul 25, 2006 07:24 PM
Type_R_Glenn
Jul 26, 2005 12:56 PM
iGoneRacing_GSR
Aug 19, 2003 02:13 PM
