EG shocks on EK
Old Jul 10, 2007 | 01:39 PM
StoCkReDlineR's Avatar
Default EG shocks on EK
hey guys
quick question will the EG shocks fit on a EK. i heard that i'll need some washer for the rear shocks, is this true, if so what size washers
thanks
Old Jul 10, 2007 | 01:47 PM
DecentCivicZ6's Avatar
B A N N E D
yeah it think 88-2000 use the same basicly
Old Jul 10, 2007 | 01:50 PM
Default Re: (DecentCivicZ6)
cool
Old Jul 10, 2007 | 01:54 PM
93egSLEEPER's Avatar
Default Re: (StoCkReDlineR)
the shock/struts are interchangable....the springs arent. same part for struts though.
Old Jul 10, 2007 | 01:59 PM
Default Re: (93egSLEEPER)
good deal guys thanks
Old Jul 10, 2007 | 02:00 PM
what struts are you going with? stock or aftermarket?
Old Jul 10, 2007 | 02:37 PM
ej6_jdm's Avatar
hmm.. that helped me too thanks!
Old Jul 10, 2007 | 02:45 PM
snakepirates's Avatar
Default Re: (ej6_jdm)
I'm actually wondering the same thing as I'm taking the shocks/springs off my eg and putting them on my ek. The only things that are the same are the front shocks. The rear shocks are different - the bushing thickness is different - although I guess you could always be ghetto and use washers to make up the difference. the spings are different too - although some companies say 92-00.
Old Jul 10, 2007 | 02:46 PM
Cee_mon's Avatar
Wrong... The springs are interchangable from 92-00, but the struts will need washers in the rear. I know cause i have the washers in front of me and they are 5mm in thickness. Other dimensions are 19mm wide with the center hole being 10mm.
Old Jul 10, 2007 | 03:16 PM
jdmztrane's Avatar
Default Re: (Cee_mon)
Cee_mon is right. Youre gonna need washers as spacers because the base of the eg shock is a good bit larger than the ek. I wend to ace hardware and got 6 for each side. Just get any washers that will fit your LCA/Shock bolt and youll be straight.
As for the fronts, yeah theyll fit, theyre the same.
Springs are interchangable.
Old Jul 11, 2007 | 10:42 AM
Default Re: (jdmztrane)
thanks guys ya the rear will need washer
Jlamar757
Suspension & Brakes
Apr 6, 2006 08:33 PM
Breeze
Aug 11, 2003 11:25 PM
Andres-eh2
May 16, 2003 01:44 PM
GummyBeng
Apr 22, 2002 05:49 AM
