EG shocks on EK
EG shocks on EK
hey guys
quick question will the EG shocks fit on a EK. i heard that i'll need some washer for the rear shocks, is this true, if so what size washers
thanks
thanks
Re: (ej6_jdm)
I'm actually wondering the same thing as I'm taking the shocks/springs off my eg and putting them on my ek. The only things that are the same are the front shocks. The rear shocks are different - the bushing thickness is different - although I guess you could always be ghetto and use washers to make up the difference. the spings are different too - although some companies say 92-00.
Re: (DecentCivicZ6)
Wrong... The springs are interchangable from 92-00, but the struts will need washers in the rear. I know cause i have the washers in front of me and they are 5mm in thickness. Other dimensions are 19mm wide with the center hole being 10mm.
Re: (Cee_mon)
Cee_mon is right. Youre gonna need washers as spacers because the base of the eg shock is a good bit larger than the ek. I wend to ace hardware and got 6 for each side. Just get any washers that will fit your LCA/Shock bolt and youll be straight.
As for the fronts, yeah theyll fit, theyre the same.
Springs are interchangable.
Breeze
08-11-2003 11:25 PM
