help me...3rd to 2nd over 9000rpms while sparying :(
Old Jun 8, 2002 | 09:44 AM
Doogie Howser's Avatar
Default help me...3rd to 2nd over 9000rpms while sparying :(
well i really fucked up, i just got my head back a few weeks ago to get some bent valves replaced and now i decided this moring after everthing has been settled that ill use my nitrous.
I was spaying in second then shifted 3rd sparying up to around 7800 then being the dumbass that i am i shift mis-shift and shift into second, goes over 9000rpm, i have the zex kit so i believe that because i was not at wot while i shifted into 2nd that it hopefully wasnt spaying but im not sure, after i misshift my car died, i rolled to the side of the road, closed my bottle wait a few seconds and tired starting it up, it started like **** and sounded like it was bogging out, i drove to my hous and it starts better and doesnt sound that bad.
its a 94 gsr with 120,000 miles on it, my questions are, would the nitrous still been shooting when i hit the fuel cutoff when i shifted to second and also how bad is this going to be, do you guys think the engines shot, or could it be ok, please help and give me some advice. sorry this is so long
Old Jun 8, 2002 | 10:47 AM
uNF$@#!'s Avatar
Default Re: help me...3rd to 2nd over 9000rpms while sparying :( (mlambrecht)
NOS + genius = blown motor
back to getting more bent valves replaced.!
[Modified by 00-0187, 2:47 PM 6/8/2002]
Old Jun 8, 2002 | 10:54 AM
obd2gsr's Avatar
sounds like you bent some more valves...
Old Jun 8, 2002 | 11:31 AM
SlowazzGSR's Avatar
Default Re: help me...3rd to 2nd over 9000rpms while sparying :( (obd2gsr)
Ya, definetly not a smart idea. You definetly did some kind of valve bend. Do a compression test and that should give u the answer u need. This time try titanium retainers for future f!ckups.
Old Jun 8, 2002 | 12:16 PM
Chubz's Avatar
Default Re: help me...3rd to 2nd over 9000rpms while sparying :( (SlowazzGSR)
Way to go smartron! Seriously you could have done some if not the same damage to your engine.
Old Jun 8, 2002 | 12:36 PM
EagleR's Avatar
Default Re: help me...3rd to 2nd over 9000rpms while sparying :( (SuperTech)
juhheezzzus crrrrist.....
Old Jun 9, 2002 | 08:12 AM
Audipwr1's Avatar
Default Re: help me...3rd to 2nd over 9000rpms while sparying :( (EagleR)
maybe use the money to learn to shift....
I have never misshifted in my life, like good old Bob Bondurant says, shifting fast isnt what you want, shifting cleanly and smoothly is or something to those lines
Old Jun 9, 2002 | 08:41 AM
Jesse H's Avatar
Default Re: help me...3rd to 2nd over 9000rpms while sparying :( (Audipwr1)
Old Jun 9, 2002 | 09:56 AM
DrewGSR's Avatar
Default Re: help me...3rd to 2nd over 9000rpms while sparying :( (Jesse H)
sounds like you bent your valves. If you take it to a dealership, I heard they charge like $1000-1500 to fix it, but you can always get it done cheaper at a private shop. Like they said, take the compression test. Does your car stall when your at a stop and is your idle rpms really low? Ask them to save the valves that got bent and post pics of them, I wanna see if you have a serious bent or a very slight one.
Old Jun 9, 2002 | 10:02 AM
vtecdc2's Avatar
Default Re: help me...3rd to 2nd over 9000rpms while sparying :( (DrewGSR)
howd u manage to misshift from 2nd back to 2nd????
Old Jun 9, 2002 | 12:17 PM
The Factor's Avatar
Default Re: help me...3rd to 2nd over 9000rpms while sparying :( (HoL Lee SHieT)
i think he missed 3-4 and went 3-2
Old Jun 9, 2002 | 01:53 PM
acurism's Avatar
New User
Default Re: help me...3rd to 2nd over 9000rpms while sparying :( (88Legend)
i think you should take it easy on your car and practice shifting and downshifting at a relatively low rpm. once you get the hang of it then you can take it up there. leave that for the people who know how to drive stick for now. maybe you should slap a low revlimit on that bad boy as well until you get the hang of it.
Old Jun 9, 2002 | 01:58 PM
ingrate's Avatar
25 Year Member
Default Re: help me...3rd to 2nd over 9000rpms while sparying :( (acurism)
low rev limiter still isn't going to save him from a 3-2 misshift. i figured he would've been more careful shifting after he blew up his engine the first time
Old Jun 9, 2002 | 04:48 PM
SlowazzGSR's Avatar
Default Re: help me...3rd to 2nd over 9000rpms while sparying :( (In7egrity)
The best thing he can do imo is since he is going to have to replace valves, add titanium retainers while the head is off. I recomend ti retainers to pretty much everyone if u gotta pull the head anyways.
Old Jun 9, 2002 | 06:29 PM
thanks for all the smart *** relpies, it ended up i didnt bend any valves
Old Jun 9, 2002 | 07:47 PM
SlowazzGSR's Avatar
Smart *** replies for a smart honda owner.
Old Jun 9, 2002 | 08:02 PM
Night_Minx
Guest
Posts: n/a
well then what the hell did you do to it
-black spoons, you know the rest-
good luck.
Old Jun 9, 2002 | 08:09 PM
tonydatyga's Avatar
you want advice? what kind of advice? you lack discipline
Old Jun 9, 2002 | 08:20 PM
SlowazzGSR's Avatar
Default Re: help me...3rd to 2nd over 9000rpms while sparying :( (tonydatyga)
Im also interested....if u didnt bend valves what did u do? Not trying to be asses but when someone just had their head rebuilt, u dont go unloading n2o on to it. Use some common sense man.
Old Jun 9, 2002 | 10:20 PM
ingrate's Avatar
25 Year Member
how about some stiffer valve springs in case you misshift again? it wouldn't be a bad investment
Old Jun 9, 2002 | 10:45 PM
gsrapper's Avatar
New User
not too smart but how did you not **** anything up????????
Old Jun 10, 2002 | 01:04 AM
NOSed_b18b's Avatar
Where's the common sense in your statement??? It's not like he was spraying while ring break in. Huh???
Bored&Stroked
Jul 18, 2013 02:11 AM
jdmRus
Sep 13, 2005 02:59 PM
HolyWater
Nov 19, 2002 12:18 PM
Doogie Howser
Jun 8, 2002 03:43 PM
B20-T
May 12, 2002 05:19 PM
