H22 ecu
Old Jul 10, 2007 | 11:10 AM
hybrid2007's Avatar
Default H22 ecu
I'm looking to swap out my p13 for a chipped p28 running Hondata but will this be a straight swap or are there things i have to sort out for it to work properly? What do i do about the knock sensor?
I've done a search but havn't come up with anything.
Old Jul 10, 2007 | 11:12 AM
PrecisionH23a's Avatar
Default Re: H22 ecu (hybrid2007)
With a p28 you will lose the knock sensor. You simply disable it in the hondata software. If you need a socketed p28 unit or s100/200/300 drop me a PM. We've got them in stock and ready to ship
Old Jul 10, 2007 | 11:19 AM
98vtec's Avatar
moderator emeritus
Default Re: H22 ecu (PrecisionH23a)
also lose IAB control, EVAP, EGR
whoever chips your ecu can add IAB control by simply adding a jumper wire...i forget what pin tho.
It will be a direct swap. You are currently OBDI, i take it, since you are running a p13.
hybrid2007's Avatar
cheers for the quick reply, will pm shortly
Old Jul 10, 2007 | 11:25 AM
hybrid2007's Avatar
Ye i'm obd1.
I was planning on blocking off my EGR valve so thats not a problem.
Will losing EVAP effect my set up much if attall?
Old Jul 10, 2007 | 11:29 AM
Default Re: (hybrid2007)
You can ditch your evap with no problems as well.
98vtec's Avatar
moderator emeritus
no.
Old Jul 10, 2007 | 11:45 AM
hybrid2007's Avatar
Are there any how-to's on removing the system or can i just leave everything as it is?
Old Jul 10, 2007 | 11:47 AM
98vtec's Avatar
moderator emeritus
you can leave it. i took it out because the canister is humongous and it allowed me to mount my catch can by taking it out.
flyrod
Aug 24, 2007 05:06 AM
RTW DC2R
Apr 4, 2006 09:42 PM
stRodda
Oct 14, 2003 11:54 PM
ziggity
Dec 25, 2002 08:57 AM
brcivic411
Jul 25, 2002 05:57 PM
