can't seem to get brake line off!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 10, 2007 | 10:17 AM
philosofy1's Avatar
Default can't seem to get brake line off!!!!!!!!!!!!!!!!!!!!!!!
ok, i'm finishing up my brake swap and i am trying to disconnect the hard line from the prop valve. i got 4 out of the 6 already disconnected, but i can't seem to break loose the other 2.
i have provided a link showing which 2 line:
http://www.thehondapartsstore....ch=no
line #14 and #11 are the ball busters. now i don't mid replacing line #14 because it's right in the fron and only costs about $5. but line #11 runs to the rear and is about $100.
anybody have any solution to my dilema? how can i go about removing it w/o stripping the fitting? i have the open ended wrench just for brake lines (10mm)
and i have tried the vise grip. i drenched it in wd40 for 2 nights now prior to the removal, and still nothing. i really don't want to spend $100, i'm on a really tight budget.
Old Jul 10, 2007 | 10:20 AM
akunamatta's Avatar
* B A N N E D *
vise grips, if they wont get it off then its siezed.
Old Jul 10, 2007 | 10:27 AM
instructor74's Avatar
Default Re: (akunamatta)
You could try a little heat around the nut on the prop valve just be careful not to heat up the hard line with direct flame they melt really easy. Oh have some thing on hand in case of fire
Old Jul 10, 2007 | 11:48 AM
philosofy1's Avatar
Default Re: (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">You could try a little heat around the nut on the prop valve just be careful not to heat up the hard line with direct flame they melt really easy. Oh have some thing on hand in case of fire</TD></TR></TABLE>
yeah i have tried this already. this is how i got 2 of the 4 that are currently loose.
any other ideas?
it seems those line have been there from factory. never removed.
Old Jul 10, 2007 | 11:50 AM
akunamatta's Avatar
* B A N N E D *
your just going to have to twist it off... theres nothing you can do but hope it doesnt crack a hardline.
Old Jul 10, 2007 | 11:56 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akunamatta &raquo;</TD></TR><TR><TD CLASS="quote">your just going to have to twist it off... theres nothing you can do but hope it doesnt crack a hardline.</TD></TR></TABLE>
hmmm...there has to be another way.
how hard is it to flare the lines up? maybe if i cut the line as close as i can to the prop valve, then reflare it might work?
Old Jul 10, 2007 | 12:06 PM
akunamatta's Avatar
* B A N N E D *
possibbly, you will have to track down a snap-on truck and get the right tool though.
justinball1717
Honda Civic (2001 - 2005)
Oct 24, 2016 06:43 PM
supaman
Aug 1, 2016 05:27 AM
ESP.net
Suspension & Brakes
May 29, 2010 09:19 PM
BlitzSix
12
Jul 1, 2009 10:55 PM
turbospool
Aug 10, 2003 11:38 AM
