Help! clutch is gone? can't pass 55mph on 5th gear
Old Jul 9, 2007 | 06:32 PM
Spoonerz's Avatar
Default Help! clutch is gone? can't pass 55mph on 5th gear
For some odd reason my 93 civic coupe's 4th gear can not pass 40mph and the fifth gear can't past 55mph. The lower gears seem to be fine but, i can not travel on the freeway. Is this a clutch problem? The car has been back in forth from Fresno to L.A. within the week. I just barely did a basic oil, spark plug tune up on the car. Any help is appreciated thanks.
Old Jul 9, 2007 | 06:34 PM
ke98248's Avatar
Default Re: Help! clutch is gone? can't pass 55mph on 5th gear (Spoonerz)
Doesn't sound like it. hmm, that sucks I can go 52 in 2nd gear.
Old Jul 9, 2007 | 06:48 PM
Aralliius's Avatar
have u tryd shifting like u where racing? idk if this would help or ne thing but wth worth a shot
Old Jul 9, 2007 | 07:07 PM
Spoonerz's Avatar
I don't want to risk causing more problem for the car. It just don't seem to want to go any faster than what the gears will let it. it's a EX and it was normal until another long drive to L.A.
Old Jul 9, 2007 | 07:08 PM
ke98248's Avatar
Default Re: Help! clutch is gone? can't pass 55mph on 5th gear (Aralliius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aralliius &raquo;</TD></TR><TR><TD CLASS="quote">have u tryd shifting like u where racing? idk if this would help or ne thing but wth worth a shot</TD></TR></TABLE> Worst advice ever.. lol.
Bump for more knowledgeable people
Old Jul 9, 2007 | 07:32 PM
Jhonny Ricer's Avatar
Default Re: Help! clutch is gone? can't pass 55mph on 5th gear (ke98248)
Does the motor start racing while your staying at that 55 mph if it doesnt it wouldnt be a clutch prob I dont think, If your clutch wer slipping or blown it and was able to get up to that certain RPM before loosing grip the motor would start accelerating while you are going nowhere. Any bogging at all Accelerating before your car cuts off speed? Id think its a timing issue, spark plug gap could be incorrect, Timing could be off or your wires to dizzy may be on in the wrong order if you took them off during the tune up. Or you could be running out a cylinder or more I know when I a rocker arm it was broken where it would slide up and down the cylinder wall for a while at first and while it was doing this the car wouldnt go past just about 55MPH in fifth. So it was like i was running on only 3 cylinders.
Old Jul 9, 2007 | 08:09 PM
Spoonerz's Avatar
Default Re: Help! clutch is gone? can't pass 55mph on 5th gear (Jhonny Ricer)
Everything was fine until i reach L.A from Fresno then this happened. going from 90-100mph to L.A. had to be there at 8:30.
Old Jul 9, 2007 | 08:33 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Clogged cat?
Old Jul 9, 2007 | 08:45 PM
Keeper1343's Avatar
Default Re: Help! clutch is gone? can't pass 55mph on 5th gear (oneludesol)
Or you can do it the crazy way.... Beat the hell out of it until something breaks then you'll know what is "was" haha
Old Jul 9, 2007 | 09:06 PM
95vxtealhatch's Avatar
There is insufficient data to conclude any sort of problem. Your obviusly not mechanically inclined. If you can tell me what noises for car is making that differs from a normal driving car then its really out of my hands. I suggest you do alot more research on how a motor works, or hand it over to someone who knows more about diagnossing the problem.
Old Jul 9, 2007 | 09:38 PM
MiX's Avatar
MiX
drive about 30 mph and then put the car in 5th gear and floor it, if the car slips and the revs jumps then its you clutch, if the car bogs and trys to accelerate its another problem.
Old Jul 10, 2007 | 05:51 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: (MiX)
95vxtealhatch & MiX are on point.
Old Jul 10, 2007 | 06:27 AM
perseverance's Avatar
as one of the poster's asked before... is it revving high past a certain mph? if not, then it's not your clutch. when your clutch is slipping it'll feel as if you were launching... it'll rise... bounce, possibly hit the limiter and you won't be going anywhere. try and start in 5th gear.. see if u can go without stalling out. if it doesn't stall, then it's ur clutch.
Si_chRis
Feb 16, 2007 07:05 PM
VtecAdvantage
Jul 23, 2006 02:43 PM
vtec25
12
Jun 15, 2006 07:58 PM
Revi
Dec 4, 2003 12:45 PM
djtony5
Jan 5, 2003 06:43 PM
