Swappin b16a2 into a 99-00 ex...mount ?
Old Jul 9, 2007 | 02:38 PM
SIRIUS VTEC's Avatar
Default Swappin b16a2 into a 99-00 ex...mount ?
are the mounts the same or would i need to replace the d16y8 mounts? im contemplating on doin a b16 swap.
Old Jul 9, 2007 | 02:39 PM
B16b-EJ8's Avatar
Default Re: Swappin b16a2 into a 99-00 ex...mount ? (SIRIUS VTEC)
You need the mounts from a 99-00 Si....please search
Old Jul 9, 2007 | 02:58 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: Swappin b16a2 into a 99-00 ex...mount ? (B16b-EJ8)
Mounts off a 1999-2000 Civic Si along with the Rear Transmission Bracket. Add axles to the list and your about set
Old Jul 9, 2007 | 03:01 PM
how about ecu...and wiring harness?
Old Jul 9, 2007 | 03:48 PM
USDMCIVICHATCH's Avatar
Default Re: (SIRIUS VTEC)
You guys are joking right? All the actual "mounts" are the same 96-00 period. He would need the rear T bracket from a 99-00 Si and thats it.
Old Jul 9, 2007 | 03:59 PM
lilo_goki's Avatar
wiring harness should fit..i'm not so sure about the ek models but for eg's..it would just be plug and play if u have an ex or si..and just use a p2t ecu from a 99-00 civic si and u should be good.
Old Jul 9, 2007 | 04:18 PM
EJ8CIVIC's Avatar
Default Re: (lilo_goki)
mounts of a 96-00 civic are the same?? i didnt think they were,
i beleive they are different bc of dseries to b series motors are different
Old Jul 10, 2007 | 06:38 PM
SJersey's Avatar
Default Re: (EJ8CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">mounts of a 96-00 civic are the same?? i didnt think they were,
Nope, they are the same. Just rear T bracket is all he will need.
Old Jul 10, 2007 | 06:42 PM
slowcivic2k's Avatar
Default Re: (SJersey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SJersey &raquo;</TD></TR><TR><TD CLASS="quote">
Nope, they are the same. Just rear T bracket is all he will need. </TD></TR></TABLE>
x2
Old Jul 10, 2007 | 06:51 PM
SJersey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilo_goki &raquo;</TD></TR><TR><TD CLASS="quote">wiring harness should fit..i'm not so sure about the ek models but for eg's..it would just be plug and play if u have an ex or si..and just use a p2t ecu from a 99-00 civic si and u should be good.</TD></TR></TABLE>
EK's dont have the same connection on the shock tower but you are right. If he used a P2T ECU it will work with his original harness. Harness is already an EX and would have vtec wired in already and he is set to go
All he will need is the P2T ECU, Rear bracket and axles. cant remember shift linkage but I believe he is ok. correct me if I am wrong... he may need the one piece
Old Jul 10, 2007 | 07:58 PM
yes he will also need the shift linkage from a 94-01 Integra or 99-00 Si as well
Old Jul 11, 2007 | 04:51 PM
EJ8CIVIC's Avatar
Default Re: (USDMCIVICHATCH)
i also have a question bout the swap (in the future)
will my d16y8 tranny bolts work on the b16a2 tranny to block????
Old Jul 12, 2007 | 04:45 PM
THANKS U GUYS ARE THE BEST. im def goin with a b16a2 swap now that my d16 is blown.
knappy03
Jul 28, 2011 12:49 PM
ProjectBoosted
May 15, 2007 04:28 PM
myEK=slow
13
Jul 13, 2006 09:45 PM
