using stock motor mounts for b16
im about to purchase a b16a2 and i have a 97 DX hatch... i was looking on the hasport website and all i saw were replacement mounts for a 96-00... so do my d series mounts work for a b16.? thanks in advance.... matt
Mr. Badwrench
Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">99-00 Si driver side motor mount bracket
99-00 Si Rear "L" bracket
the rest of the mounts and brackets will work</TD></TR></TABLE>
yup
but the hasport mounts are bad ***. if you have the coin, throw down.
yup
one more question.... will i have to get an obd2A to obd2b conversion harness... like for the dash? my friend brought it up and confused the hell out of me.
Re: (myEK=slow)
just forget the mounts...get an aftermarket driver side upper mount from like avid or innovative...works just like hasports...just cheaper in price. looks nice too! also stronger than the 96-00 civic driver side upper mount.
take a t-bracket from a 96 del sol dohc vtec or a 99-00 si
if you are going to use the 99-00 si ecu, you will need to get a conversion harness for your obd2a to the ecus harness which is obd2b. but if you want, it would be better to just get an obd1 ecu and the conversion harness...makes everything easier...i'm using a conversion harness to run my obd1 ecu in my obd2a vehicle harness
and about the confusion...
obd2a is for the 96-98 civics and obd2b is for the 99-00 civics no matter what model it is...
you can not use a 99-00 ecu in a 96-98 civic unless you have the harness visa versa...
but if you could get an obd1 ecu...it'd be better...
good luck with your swap...
Re: using stock motor mounts for b16 (myEK=slow)
Re: (myEK=slow)
1) P75 won't work... u need a vtec ecu... unless u don't want vtec.
2) ur DX wiring harness doesn't have the vtec wiring so you'll either have to wire it in (3 wires) or get an ex harness
3) conversion harness will depend on what ecu u're going to run
Here's a pretty good write up: http://www.phear7imports.net/trey/6gen/
EM1 Resto
09-24-2009 01:28 PM
