Hesitation help!
Old Jul 9, 2007 | 12:02 PM
97CWITR's Avatar
Default Hesitation help!
At a steady throttle or during moderate excelleration im getting a definite hesitation and bogging.
I'll continually hold the pedal down but it wont accelerate occasionallly, until I lift off and tap the gas a little harder. This happened when I was on the highway and the rpms just started dropping slowly.
It really feels like a fuel issue. Like its not getting fuel until I lift off the gas and press down again.
122,xxxkms b18c
changed the fuel filter 2,xxxkms ago
stock injectors, stock fuel pump
Wondering if I should just order a new walbro 190lph fuel pump and see what happens?
Anything else I should check?
Old Jul 9, 2007 | 12:04 PM
Spoon ITR's Avatar
Default Re: Hesitation help! (97CWITR)
i had a similar problem.
changed the distributor and she was better than new
JjuuN R's Avatar
Where do you live? could just severe heat...
Old Jul 9, 2007 | 12:23 PM
97CWITR's Avatar
Default Re: Hesitation help! (Spoon ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon ITR &raquo;</TD></TR><TR><TD CLASS="quote">i had a similar problem.
changed the distributor and she was better than new</TD></TR></TABLE>
My distributor went in my old gsr before, and this feels different. Is there anyway to test it to confirm a faulty distributor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">Where do you live? could just severe heat...</TD></TR></TABLE>
It was 84 and raining...I'm sure everyone else doesnt have this happen during similar weather.
Old Jul 9, 2007 | 12:25 PM
rjgerolaga's Avatar
that could be your problem. are you trying to lock up the motor.
Old Jul 9, 2007 | 12:33 PM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97CWITR &raquo;</TD></TR><TR><TD CLASS="quote">
It was 84 and raining...I'm sure everyone else doesnt have this happen during similar weather.</TD></TR></TABLE>
There are a few different things inside a dizzy, your problem last time might not be the same problem this time.
If you have a spare coil or ignitor, you can take the dizzy apart and swap them out.
Old Jul 10, 2007 | 03:50 AM
97CWITR's Avatar
Default Re: Hesitation help! (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">
If you have a spare coil or ignitor, you can take the dizzy apart and swap them out. </TD></TR></TABLE>
Would a distributor issue be felt constantly? I drove around for 25minutes today and everything seems fine now...
Old Jul 10, 2007 | 06:17 AM
walker111's Avatar
Would a distributor issue be felt constantly? I drove around for 25minutes today and everything seems fine now...</TD></TR></TABLE>
The dizzy problems I've had have been on and off, sometimes the car works fine, sometimes it hesitates/sputters, then it leaves you stranded somewhere..
Old Jul 10, 2007 | 09:31 AM
itr1244's Avatar
it should be just regular tune up..
inspect/replace the following.
spark plugs.
dizzy cap/ rotor
maybe the wire.
Old Jul 10, 2007 | 10:56 AM
rjgerolaga's Avatar
Default Re: Hesitation help! (rjgerolaga)
i thought i saw him posted in mid throttle or wot during rain... i must be seeing things or its been change.
Old Jul 10, 2007 | 12:58 PM
97CWITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjgerolaga &raquo;</TD></TR><TR><TD CLASS="quote">i thought i saw him posted in mid throttle or wot during rain... i must be seeing things or its been change.
Nope.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">it should be just regular tune up..
spark plugs.
dizzy cap/ rotor
maybe the wire.
replaced wires, plugs..cap and rotor up next
Old Jul 10, 2007 | 02:07 PM
jetydosa's Avatar
25 Year Member
Does it go away if you hit WOT? If so I had the same exact problem and it was bad O2 sensor. You can reach below the throttle body and disconnect at the wiring clip. Youll get a CEL but if car runs fine after that, you know its the problem.
Old Sep 23, 2009 | 05:38 PM
H22 CB's Avatar
What was the problem? I have the same exact problem.
santacruzccs
Apr 14, 2011 08:34 AM
dsturch1
Oct 15, 2007 10:47 AM
go2sleep
May 4, 2007 07:19 PM
Dorby
Mar 26, 2006 06:19 AM
mini-v-si
Jun 1, 2004 03:06 PM
