timing belt ?
Old Jul 8, 2007 | 10:53 PM
eg714's Avatar
Default timing belt ?
i just pick up a 99 integra gsr and when i pop the valve cover off today i notice the timing belt wasnt a honda belt but a napa belt and was kind of loose when i touch it (i could slip it off the cam gears easily). so my ? is do you guys think i need to change it out for a new oem one or just leave it as is with the napa timing belt in it? the car is completely stock with 107,000 miles on it. thanks in advance
Old Jul 9, 2007 | 06:21 AM
Padawan's Avatar
Darth ModerVader
Default Re: timing belt ? (eg714)
The fact that it's a Napa belt isn't necessarily a problem (though for the cost of a new OEM belt, I'd probably just replace it). The real issue is the improper tension that your belt appears to be set at. If it were me, I'd pick up a new belt, water pump, tensioner pulley and tensioner spring, and do the replacement myself.
redturds
Honda Civic (2001 - 2005)
Apr 21, 2019 06:41 PM
VegaS10
May 20, 2013 12:05 PM
ALLxMotor DA
Sep 6, 2008 06:10 AM
honda94accord
Apr 10, 2007 05:39 AM
importboi22
Jan 18, 2005 09:05 PM
