speedo going crazy!!
Old Jul 8, 2007 | 09:53 PM
cmasonrun's Avatar
Default speedo going crazy!!
my speedo is bouncing up and and down and all around, lol, but if i turn my cruise control on, but dont set it, the speedo works fine. whats weird is my cruise control has never worked, and i just recently put a b20 vtec in my car,
once idea i had was the vss or the cluster, but i have an ITR intake manifold, so there is once less place to put a vaccum line to it..... any suggestions, sorry if this is real confusing....
Old Jul 8, 2007 | 09:56 PM
SirRevvs's Avatar
Default Re: speedo going crazy!! (cmasonrun)
If your speedo is bouncing around my guess would be either the vss or speedo cluster. Leaning more towards a bad cluster.
Old Jul 8, 2007 | 10:52 PM
cmasonrun's Avatar
Default Re: speedo going crazy!! (SirRevvs)
but why would the cruise control being on change it? and make it work again?
Old Jul 8, 2007 | 11:56 PM
cmasonrun's Avatar
bump
Old Jul 9, 2007 | 12:53 AM
mckrank313's Avatar
my car did this... right before i blew the fuse for for my vss....
everytime this has happened to me my speed sensor stops working... so then once i fix it it makes the speedo stop bouncing up and down...
Old Jul 9, 2007 | 12:57 AM
cmasonrun's Avatar
Default Re: speedo going crazy!! (mckrank313)
so your saying its the VSS? and i should just replace that?
Old Jul 9, 2007 | 06:33 AM
speedooo's Avatar
mine did that and it turned out the plug on the harness was bad and it wasnt making constant contact. i went out of my way and changed my cluster and bought a vss and it was the harness
Old Jul 9, 2007 | 01:00 PM
mckrank313's Avatar
sorry i didn't make my post very clear what i meant to say is that everytime it happens i check the vss plug... (i think mine is not exactly 100%) and then i change the fuse... it has never been the vss
i have had this happen like 4 times in the last year and everytime it hasn't been a bad vss
Old Jul 9, 2007 | 02:26 PM
mustang5.slow's Avatar
* B A N N E D *
Default Re: speedo going crazy!! (speedooo)
double check your grounds.
Old Jul 9, 2007 | 03:28 PM
Keeper1343's Avatar
Default Re: speedo going crazy!! (mustang5.slow)
i'm with him ^^^^..... maybe its stops bouncing because when you turn the cruise on it has its own ground and runs through that???? Just a wild guess.....
Old Jul 9, 2007 | 03:43 PM
mikebpem1's Avatar
Default Re: speedo going crazy!! (Keeper1343)
when i cruised in neutral my rpm's bounced like a mad man
solution.........-vaccum leak.
Old Jul 9, 2007 | 03:45 PM
Keeper1343's Avatar
Default Re: speedo going crazy!! (mikebpem1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikebpem1 &raquo;</TD></TR><TR><TD CLASS="quote">when i cruised in neutral my rpm's bounced like a mad man
solution.........-vaccum leak.</TD></TR></TABLE>
But then how does that explain the cruise control switch fixing it...... ground is my guess
Old Jul 9, 2007 | 04:48 PM
FastLife617's Avatar
i had the same issue a week ago it happend to be my grounds just make sure your grounds have a good contact try to clean the surfaces with some sand paper worked for me
Old Jul 17, 2007 | 11:34 AM
* B A N N E D *
Default Re: speedo going crazy!! (FastLife617)
hope you fixed that problem...cause if it's the grounds. the ground screw will only get looser with the engine vibes and the ground will actually effect your sparks and make the motor Skipp bangs on your pistons. and the feel nasty. cause you car briefly tries to stop.
406EVO
May 18, 2016 11:26 AM
Manlion
Mar 29, 2010 03:19 PM
civicDX2178
May 3, 2006 06:43 AM
accordianex
Feb 14, 2006 12:15 PM
