Turbo Coolant Return Line and thermostat flow
Old Jul 8, 2007 | 07:24 PM
Muckman's Avatar
Moderator in Chief
Default Turbo Coolant Return Line and thermostat flow
I know this has been discussed a million times but my question has to do with how the thermostat affects coolant flow.
Originally I was going to use the 1/8 NPT side port on this barbed fitting that came with the Victor X manifold. But its not really big enough for a -6 AN line and Im not sure if this bypass hose gets coolant when the tstat opens. Can anyone confirm if this bypass line gets flow both when the tstat is open and closed?
My 2nd option is to tap the back of the thermostat housing like in this picture (left smaller black plug on the tstat housing). Does the back of the thermostat get flow when the tstat is open and closed? Thanks to haydenpothoven for the picture.
Old Jul 9, 2007 | 11:53 AM
Muckman's Avatar
Moderator in Chief
Default Re: Turbo Coolant Return Line and thermostat flow (Muckman)
Nobody knows how the thermostat controls coolant flow?
Old Jul 9, 2007 | 12:08 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
This is why I stick to oil-cooled turbos. Too complicated for me.
Old Jul 9, 2007 | 12:45 PM
.adam.'s Avatar
i ran all last year with one of my coolant lines coming from that fitting with the victor x and then teed with the lines that go to the throttle body
Old Jul 9, 2007 | 01:13 PM
hovic's Avatar
Default Re: (civicskater)
I´ve got the Fast Turbo coolant line kit and it comes with a weld on fitting for the water pipe. If you´ll go with the second option it´s the same situation. The return line is still before the thermostat so I don´t see a problem. I tapped my thermostat housing too because I don´t want to use the weld on fiting. A 6AN fitting fits perfect!
Old Jul 9, 2007 | 05:33 PM
Muckman's Avatar
Moderator in Chief
Default Re: (hovic)
Where did you guys tap your coolant FEED from?
I was going to drill and tap the bleeder valve.
Old Jul 10, 2007 | 06:30 AM
sp00led's Avatar
Default Re: (Muckman)
Is your block OBDI? I ditched the factory oil cooler and used the leftover coolant ports to feed the turbo. I tapped the lower portion of my radiator for the return line.
Old Jul 10, 2007 | 06:39 AM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Where did you guys tap your coolant FEED from?
cant really answer your question as far as flow, but i feed from a hole tapped into the tstat housing. and return to bottom of radiator.
Old Jul 10, 2007 | 07:06 AM
Muckman's Avatar
Moderator in Chief
Default Re: (sp00led)
No its OBD2 B18C1, so it doesnt have the bleeder valve or the oil cooler.
Old Jul 10, 2007 | 07:08 AM
Topdawgg's Avatar
I just used the fitting off the side of my victor X that had the spot for the small line.. and i fed the other one off a T from my thermostat line...
as long as its a loop including the turbo, feed and return dont really matter IMO, the coolant system is always flowing... so as long as the turbo has coolant, you're good to go
Old Jul 10, 2007 | 07:34 AM
Muckman's Avatar
Moderator in Chief
Default Re: (Topdawgg)
Well if there isn't a difference in pressure on each line then the coolant is not going to move well.
Old Jul 10, 2007 | 08:34 AM
a1320addict's Avatar
On the front of the block, to the left of the oil dipstick is a fitting.
I am running my feed from there and return to a fitting onto my radiator.
Clean and simple
Old Jul 10, 2007 | 08:53 AM
Armed Ferret's Avatar
Default Re: (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">On the front of the block, to the left of the oil dipstick is a fitting.
Clean and simple </TD></TR></TABLE>
any chance of a photo of the radiator fitting?
Old Jul 10, 2007 | 10:35 AM
Default Re: (Armed Ferret)
Sorry I don't. It's just a -6 male aluminum weld-on.
Old Jul 10, 2007 | 01:32 PM
B18c1turboedEK's Avatar
I ran mine off that same exact spot, i used a 1/8 too 6an fitting, the i removed the fan switch and got the fitting for there and used that as a feed or return .im not sure how its flowing.But i know 1 is before the thero and one is after.
Old Jul 10, 2007 | 01:53 PM
hovic's Avatar
Default Re: (B18c1turboedEK)
sorry for the bad pic..
On the left you can see the feed line fitting and in the right (thermostat housing) is the fitting for the return line.
and here´s a pic of the original thermostat housing:
Modified by hovic at 2:19 PM 7/11/2007
Old Jul 10, 2007 | 02:06 PM
jdmturbo1127's Avatar
The easiest way is to just put the lines between the TB and the IM as described in the instructions for the Edelbrock turbo kit. Download the instructions from their site.
Old Jul 10, 2007 | 02:36 PM
Muckman's Avatar
Moderator in Chief
Default Re: (jdmturbo1127)
That is not what this thread is about.
codenamezero
Mar 23, 2012 02:51 PM
done
Oct 14, 2005 12:24 PM
Rubixcu7
Jul 11, 2005 08:27 PM
Krayzielix
Jun 17, 2004 03:42 AM
ScottEK
Oct 30, 2002 09:42 PM
