Fuel pump???
Old Jul 8, 2007 | 05:04 PM
The Dirty EJ1's Avatar
Default Fuel pump???
(d16z6 turbo)
Well I was driving (beating on the motor some) yesterday and I turned into my friends neighborhood then all of a sudden it acted as if I ran out of gas but like I ran out REALLY fast(i have 1/4 tank left). So I go to start it up again and it acts like it ran out of gas... I
just boosted it like 3weeks ago and never upgraded the fuel pump.... AND i know my fuel gauge works.... SO I'm 98% sure its my fuel pump, but then again I guess I would ask yall.
Old Jul 8, 2007 | 05:05 PM
ke98248's Avatar
Default Re: Fuel pump??? (The Dirty EJ1)
May want to try Forced Induction forum too. Not sure, but it kinda sounds like fuel pump. wait for somebody else to respond.
Old Jul 8, 2007 | 05:17 PM
forcefedferio's Avatar
Default Re: Fuel pump??? (ke98248)
can you hear the pump priming? since you're only at a 1/4 tank try sticking a funnel in the fuel filler neck and listen while someone turns the key to the "ON" position. if it doesnt prime check the fuses and main relay, if those check out ok then replace the pump which is a good idea regardless since you said you haven't already.
Old Jul 8, 2007 | 05:27 PM
Default Re: Fuel pump??? (forcefedferio)
It does sound like its priming, but I go to start it and also tap the gas the CEL comes on
but only when I tap the gas (I know, I know its fuel injected but its still some sort of sign right?) lol
lmananT
Jun 4, 2008 10:56 PM
The Dirty EJ1
Jul 8, 2007 05:58 PM
huge230
Jun 19, 2007 02:58 PM
arospeedintegra
Mar 6, 2007 02:26 PM
dyases
Apr 30, 2004 06:45 PM
