94 eg hatch dash?
alright i need to remove my dash from my hatch..i have every bolt off..but it still dosent want to come out..so far i removed
-2 bolts on the side
-top vent bolt
-removed glovebox
-bolts above glove box
-bolt under the radio by the cup holder
its loose but wont seem to break free around the passenger air bag part..please help me i need to get this out..
-top vent bolt
-removed glovebox
remove speedo.. unbolt the ground under there.. you will see it...
also remove all plugs from radio, fuse box, and a/c controls
i do this like once a week lol
easier if you remove your steering wheel and wiper switch and headlight switch too
well i did remove the cluster and already droped the steering colum so nothing is in the way.....like i said its loose but seems like something is holding the dash back by the passenger air bag...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kjcrew_eg »</TD></TR><TR><TD CLASS="quote">Take your passenger air bag out.</TD></TR></TABLE>
forgot about that... i dont have one
take a very long extension look up in the part where your glovebox used to be and look for the 10mm bolts up there... unbolt them and lift the airbag out... that needs to come out and also make sure you take the plug for your a/c controls out right in the middle under where your radio is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 305accord »</TD></TR><TR><TD CLASS="quote">ANYONE ELSE? </TD></TR></TABLE>
why do you need more advice when i just told you the correct way to take it out... go get a manual from advance auto parts or something and it will say the same thing
no bro i believe you ..i know how to work on cars ive takin my share of dashes out but they have all been with out passenger air bag..and this is my dd i cant afford to not have it running..so i was seeing is someone who has removed a dash with passenger air bag before could give me a more descriptive way..but thanks fro your help
badream20
13
Jul 11, 2005 07:34 PM
