radiator cap (searched)
hey. i was just searching to see how a radiator cap would help with anything? i thought it was just a cap. well i searched and it said theyre only good for turbo really. would it be worth it getin a new cp with my mods? ( check my sig)
some caps are rated to hold in more pressure than others. If your motor runs hot and boils the water then it would be better to have a higher pressure cap to raise the boiling point, however it should not get that hot if you have the correct water/coolant mix
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 »</TD></TR><TR><TD CLASS="quote">some caps are rated to hold in more pressure than others. If your motor runs hot and boils the water then it would be better to have a higher pressure cap to raise the boiling point, however it should not get that hot if you have the correct water/coolant mix</TD></TR></TABLE>
If he's boiling over with a stock cap on a regular basis, either his cap's bad, or he's got a serious problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russlan44 »</TD></TR><TR><TD CLASS="quote">i have one of thouse ebay crap 1.3 i think its peice of **** im not even sure if it does any good</TD></TR></TABLE>
When my cap went bad, I picked up a TRD cap at work for cheap, but it didn't fit
