95 civic ex
Old Jul 7, 2007 | 04:08 PM
Beastywhitehatch's Avatar
Default Crazy Idle 95 civic ex
Whats up honda-tech i'm new had a question about my 95 civic ex it has the original single vtec motor 100,xxx it has this crazy idle it use to go away but now it stays it is a very fast idle from 1500 to 2000 grand i change the map, iac, and a valve called the fast idle valve so i no now it could be somethin electrical bcas none of those made a difference so i was wonderin wat it could be if u guys have ne suggestions let me know so far i think it could b electrical, tps, or a vacuum leak that i cant find or there is no check engine
Old Jul 7, 2007 | 04:10 PM
Default Re: Crazy Idle 95 civic ex (Beastywhitehatch)
ttt
Old Jul 7, 2007 | 04:11 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beastywhitehatch &raquo;</TD></TR><TR><TD CLASS="quote">Whats up honda-tech i'm new had a question about my 95 civic ex it has the original single v-tech motor 100,xxx it has this crazy idle it use to go away but now it stays it is a very fast idle from 1500 to 2000 grand i change the map, iac, and a valve called the fast idle valve so i no now it could be somethin electrical bcas none of those made a difference so i was wonderin wat it could be if u guys have ne suggestions let me know so far i think it could b electrical, tps, or a vacuum leak that i cant find or there is no check engine</TD></TR></TABLE>
most likey is a vacuum leak. i would spend sometime looking at the hoses, look for any that might be loose or dry rotten.
somebody knows somethin or have an idea lmk
Old Jul 7, 2007 | 04:12 PM
thanks keep em coming
Old Jul 7, 2007 | 04:13 PM
Ramma's Avatar
look for a vacuum leak. That's what it sounds like. Have you tried adjusting the idle with the screw in the throttle body?
Old Jul 7, 2007 | 04:15 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beastywhitehatch &raquo;</TD></TR><TR><TD CLASS="quote">most likey is a vacuum leak. i would spend sometime looking at the hoses, look for any that might be loose or dry rotten.
thanks keep em coming</TD></TR></TABLE>
your best bet, pick up a repair manual. it will walk you through on the proper step to trouble shooting. you can also spend sometime in the search forum, see what other members have discovered.
oh, and slow down on the post.
Old Jul 7, 2007 | 04:16 PM
philosofy1's Avatar
Default Re: (Ramma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ramma &raquo;</TD></TR><TR><TD CLASS="quote">look for a vacuum leak. That's what it sounds like. Have you tried adjusting the idle with the screw in the throttle body?</TD></TR></TABLE>
i wouldn't recommend it. especially if the idle screw is at it's tightest.
Old Jul 8, 2007 | 05:50 PM
Default Re: (philosofy1)
ok i'll check that out n i did adjust the idle screw made lil differece
DeloresElizabet
Oct 7, 2012 03:09 PM
2kul
11
Jul 31, 2011 10:36 AM
00 civ
15
Oct 22, 2006 08:15 PM
jabenne
Nov 18, 2003 01:52 PM
Scrapin 240
Jan 23, 2003 12:45 PM
