Must be a common problem Dust Boot Caliper Piston
The boot seems to have air pockets in it. When I screw in the piston all the way the boot on one side kinda bubbles at one end. Any suggestions. I was thinking a making a small pin hole where the bubble is to let the air out.
Thanks Madness
Thanks Madness
replace the whole boot because of air? I just need to remove the air. This has got to be a common problem with an easy fix.
I don't see the "problem." I've had many pockets of air in many dust seals. As long as you don't go poking holes or tearing the seal, it's fine.
xray328
Suspension & Brakes
Nov 28, 2010 06:53 PM
