How to mask off letters on valve cover
Been searching but cant get a straight answer. What really works when repainting the valve cover on masking the letters. I hear grease them chapstick white out. Let me know what worked for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pockets »</TD></TR><TR><TD CLASS="quote">just paint it all, then when the paint is fully cured just sand it back off</TD></TR></TABLE>
Thats what I do and it actually will look better since you are sanding it and it will shine like its brand new.
You can sand it before you paint with like 2000 grit to make sure its clean and looks good.Then after the base is on you can either take a little reducer on a rag a with a little effort take it right off.Or you can sand it off with 1000-2000 grit.Then clear
You can also put vaseline on the letters and then paint and wipe off the vaseline after paint dries... paint wont stick to the vaseline but make sure your vc is dry and not wet or it will be a mess
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 »</TD></TR><TR><TD CLASS="quote">chapstick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep1dem1c »</TD></TR><TR><TD CLASS="quote">You can also put vaseline on the letters and then paint and wipe off the vaseline after paint dries... paint wont stick to the vaseline but make sure your vc is dry and not wet or it will be a mess</TD></TR></TABLE>
works like a charm!
works like a charm!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8krdline »</TD></TR><TR><TD CLASS="quote">i put tape over the letters then cut the outline with a razorblade. after its painted just pull off the tape</TD></TR></TABLE>
Guest
Posts: n/a
i've done the tape, and done the sanding, sanding is by far better. Just use a flat object and it comes off much cleaner and perfect all around. What i did was a 600 grit going at 45 degree's one way, then 45 degrees the other way for my final sanding so it looks cross hatched
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
I did mine, i beel blatsted it, then epoxy then high build then base clear and i got 120 put it on a block and blocked it out, went the same way and made the letters look like brush alluminum... i could show pics
