How to setup the wire feeder?
Old Jul 7, 2007 | 03:31 AM
scartail's Avatar
Default How to setup the wire feeder?
I've got a Lincoln Weldpak, and the feed isn't smooth when welding. It seems to be studder. And if I turn up the feed rate, it seems to get worst.
Per the instructions, I supposed to set the resistance of the wire feeder by feeding the wire against something non-condcuctive (cement floor, etc). And turn the resistance up until I get a slight push back.
I dont' get that. I get a firm push back, and regardless of how loose I turn the resistance. What else should I be doing?
Any help? Thanks in advance.
Old Jul 7, 2007 | 03:55 AM
Howitt's Avatar
Default Re: How to setup the wire feeder? (scartail)
Check the tension on your rollers inside the unit it sounds like they are slipping
Old Jul 7, 2007 | 04:23 AM
ROTARY's Avatar
did you try to loosen up the nut holding the spool of wire?
Old Jul 7, 2007 | 04:28 PM
scartail's Avatar
I will check the roller...
The spool nut is supposely where I am supposed to set the tension.
Thanks for all the help.
San-Wan
Sep 30, 2008 07:28 AM
14bcoupe
Welding / Fabrication
12
Apr 19, 2005 11:20 AM
mrbsponge
Mar 22, 2005 08:25 PM
AllmotorEH2
Feb 28, 2005 08:48 PM
