Timing belt for 99 ex -4
Old Jul 6, 2007 | 05:19 PM
93accordsleeper's Avatar
Default Timing belt for 99 ex -4
Didn't have time to search, but my wife just bought a 99 ex f23a4 with 140k on it and timing belt was never done. Just wanted to c if its a hit or miss motor, should I get it done asap or can I push it off for a couple of weeks. Don't want to take any chances she's in love, so just trying to be safe. Thanks Guys
Old Jul 6, 2007 | 05:41 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Timing belt for 99 ex -4 (93accordsleeper)
if you can do it then don't wait.
if you need some info on how to do it, check out my write-up I did on a F22B1 (94-97 EX). That'll show you the main points of how to do it though the alignment marks might be slightly different.
The write-up can be found in the FAQ where a lot of other helpful links can be found.
Old Jul 6, 2007 | 05:54 PM
Default Re: Timing belt for 99 ex -4 (TouringAccord)
It might be a couple of weeks before I get to it, I was just wondering if it is a interference engine. If it is I'll tell her not to drive it for now but it will break her hart.
Old Jul 6, 2007 | 05:58 PM
H-T Order of Merit
yes, it is an interference engine
Old Jul 6, 2007 | 06:16 PM
Thanks man, U just spoiled my whole weekend, no but its good to know I,ll do it rite away
Old Jul 6, 2007 | 06:20 PM
H-T Order of Merit
yep, no problem. it sucks but it's always good to know
Old Jul 6, 2007 | 07:13 PM
Yah I told my wife, looks like my sunday is shot to ****. But all in all I won't have to do it for a long time. Thanks again. BTW were is a good list of interference and non interference motors I can keep on file?
Old Jul 6, 2007 | 07:18 PM
H-T Order of Merit
I don't know of a list like. Pretty much any Honda motor you are going to install in that car is going to be an interference motor.
Old Jul 7, 2007 | 08:31 AM
leviq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93accordsleeper &raquo;</TD></TR><TR><TD CLASS="quote">Didn't have time to search, but my wife just bought a 99 ex f23a4 with 140k on it and timing belt was never done. Just wanted to c if its a hit or miss motor, should I get it done asap or can I push it off for a couple of weeks. Don't want to take any chances she's in love, so just trying to be safe. Thanks Guys</TD></TR></TABLE>
I just changed my 99 4 cyl at 152k and bought her used with 41k. My buddy had a 94 EX (same engine) and ran it up to about 190k without ever changing the timing belt, and then ran his 99 4 cyl up to about 220k without ever changing it. And his typical shift point is about 6000 rpm, popping the clutch back hard on every shift.
I inspected my timing belt and it looked pristine. I'm no expert, but I couldn't spot a single crack, chip, etc. It looked just as good as the old one.
I'd say you're safe driving it another 10k if you had to.
Old Jul 7, 2007 | 01:02 PM
H-T Order of Merit
Default Re: Timing belt for 99 ex -4 (leviq)
FYI, a 94 EX and a 99 4cyl Accord do not have the same engine, similar but not the same.
Also, I've been told the signs of a timing belt going aren't going to show up until the belt is about to go.
Honda lists the change interval for a reason, stick to it
zrs6v4
Feb 19, 2012 09:43 AM
mrlover
Aug 9, 2008 01:53 PM
bmwfixer
Nov 12, 2005 02:49 PM
philip99
Oct 14, 2005 05:27 AM
