PLEASE Help Fix my Engine Codes! b16a
I have a 2000 Civic Si. It has been swapped with a JDM b16a engine using my b16a2 intake manifold, oil pump, etc (to convert to OBD2). After the swap, the check engine light is on. I found the error codes from Advance Auto Parts and they are:
P0117
engine coolant temp
circuit low input
P1508
Manf Cntrl Veh. Spd.
Idle Speed Control
Auxiliary Inputs
I have no clue how to fix these. I tried to clean the IAC valve, but nothing happened. Some problems are the high idle (about 1500), rough start when the engine is cold, and no sound of VTEC. PLEASE HELP!! I really want my VTEC working! Thanks!!
Modified by NosShootinHonda at 8:20 PM 7/6/2007
P0117
engine coolant temp
circuit low input
P1508
Idle Speed Control
Auxiliary Inputs
So after I change my coolant temp sensor and clean/replace my IACV, my CEL will go away? I'm not real sure if this is the right way to fix my codes. tell me how to fix them, if there is more to it. and does these things suppose to affect my VTEC? because when i floor 2nd gear all the way to 8200, it lags around 6000. plus you can't even hear VTEC rip in. help me out if you can!! it's well appreciated!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NosShootinHonda »</TD></TR><TR><TD CLASS="quote">So after I change my coolant temp sensor and clean/replace my IACV, my CEL will go away? I'm not real sure if this is the right way to fix my codes. tell me how to fix them, if there is more to it. and does these things suppose to affect my VTEC? because when i floor 2nd gear all the way to 8200, it lags around 6000. plus you can't even hear VTEC rip in. help me out if you can!! it's well appreciated!!</TD></TR></TABLE>
you don't know if you dont try, just borrow a friends and see how it works
nicklp60452
Jul 14, 2008 02:53 AM
