Power issue
Old Jul 6, 2007 | 12:31 PM
ITR_HO's Avatar
Default Power issue
I recently just dyno'ed my ITR
Mods;
AEM cold air
Blox manifold / stock ITR TB
Cheap DC headers ( i know i need to upgrade )
Skunk2 valve train
Skunk2 stage 2 cams / stock sprockets
JDM b16 piston/rod assembly
ITR crank
Blox fuel reg
stock fuel injectors
Stock exhaust ( im thinking this may be 1 of my probs )
I made 134 to the wheels and 174 HP....
should'nt i be pushing more?
Old Jul 6, 2007 | 12:33 PM
cmdr430's Avatar
Default Re: Power issue (ITR_HO)
you need adjustable cam gears.....
and at least a v-afc
Old Jul 6, 2007 | 12:35 PM
ITR_HO's Avatar
Also forgot to mention im running a P28 w/ crome
Old Jul 6, 2007 | 12:37 PM
BlueR's Avatar
JDM b16 piston/ rod assembly
hello? wtf?
Old Jul 6, 2007 | 12:44 PM
ITR_HO's Avatar
Higher compression....
i thought eveyone knew that.
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Power issue (BlueR)
Too many headers.
(But you do need to upgrade)
Old Jul 6, 2007 | 12:47 PM
JjuuN R's Avatar
Default Re: Power issue (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">Too many headers.
(But you do need to upgrade)</TD></TR></TABLE>
Haha.
Old Jul 6, 2007 | 12:52 PM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">JDM b16 piston/ rod assembly
hello? wtf?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR_HO &raquo;</TD></TR><TR><TD CLASS="quote">Higher compression....
i thought eveyone knew that.</TD></TR></TABLE>
We do. I believe he is referring to the shorter length of the B16 rods vs. the longer length of the B18 rods, which you should be using.
Old Jul 6, 2007 | 12:58 PM
BlueR's Avatar
hey, i'm not the one making 134hp
but wtf do i know
Old Jul 6, 2007 | 01:00 PM
ITR_HO's Avatar
Default Re: Power issue (get RIGHT)
I dont believe that alone is the root cause....
Do you think headers, especially DC ( plus some dings,dents on the bottom )
+ Stock exhaust could be more of a reason?
im still running stock Cat
Old Jul 6, 2007 | 01:31 PM
JjuuN R's Avatar
Well first off if you run more then one header you won't have sufficient back pressure...
Old Jul 6, 2007 | 01:32 PM
Comp97GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR_HO &raquo;</TD></TR><TR><TD CLASS="quote">I dont believe that alone is the root cause....
im still running stock Cat </TD></TR></TABLE>
no, you have dropped your compression significantly. Is this even a C5 block?
Why use a Blox I/M? With those cams you need more compression for them to make any power.
Old Jul 6, 2007 | 01:38 PM
KOALA YUMMIES's Avatar
::shaking head:: Why why why am I not surprised....
Old Jul 6, 2007 | 01:47 PM
MOVE OVER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">hey, i'm not the one making 134hp
but wtf do i know
I think the 134 is the tq, or is he implying that the 174 is the hp to the flywheel?
Old Jul 6, 2007 | 01:50 PM
Comp97GSR's Avatar
Here is some more food for thought.
Do you know what JDM B16 piston/rod assembly you are using?
Anyway, B16 rods are about 134mm in length. B18C rods are about 137.9mm in length.
Old Jul 6, 2007 | 02:02 PM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: Power issue (Comp97GSR)
OP&lt;***
get RIGHT's Avatar
Default Re: Power issue (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">::shaking head:: Why why why am I not surprised.... </TD></TR></TABLE>
LMAO.
Old Jul 6, 2007 | 02:03 PM
Comp97GSR's Avatar
Default Re: Power issue (MOVE OVER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOVE OVER &raquo;</TD></TR><TR><TD CLASS="quote">
I think the 134 is the tq, or is he implying that the 174 is the hp to the flywheel?</TD></TR></TABLE>
That would make more sense to me, but the OP has failed to be more thorough in posting his problem.
Old Jul 6, 2007 | 02:05 PM
Comp97GSR's Avatar
Besides, Who needs a bunch of HP to look good at a car show?
Old Jul 6, 2007 | 02:17 PM
totsie7944's Avatar
sounds like either you read the dyno results wrong or you simply lowered your compression greatly. in either case, confirm the dyno results are read correctly and go from there. Honestly your setup is all wrong tho....
Old Jul 6, 2007 | 02:50 PM
ITR_HO's Avatar
go read it again...i never said that.
And thanks for the help ( to the people who actually gave advice )
i am thinking about building the bottom end back up with ITR piston/rod assembly. My original block had a crack in it so i had to use a GSR block.
Old Jul 6, 2007 | 02:52 PM
Comp97GSR's Avatar
Change the rods to B18C rods first.
BTW, Plenty of us had read what you posted and it isn't exactly straight forward.
Old Jul 6, 2007 | 03:06 PM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">
Besides, Who needs a bunch of HP to look good at a car show? </TD></TR></TABLE>
Exactly.
Old Jul 6, 2007 | 03:39 PM
get RIGHT's Avatar
Default Re: Power issue (JjuuN R)
*Drum roll please*
And the ROTY Award goes to........ (the 2 posters above have tied)
Old Jul 6, 2007 | 08:22 PM
rjgerolaga's Avatar
thas what you call reverse performance. must be a new trends.
pootie.teng
26
May 23, 2007 10:12 PM
CRX VT-DOO
Feb 4, 2005 09:26 AM
Dom_GsR
Aug 11, 2004 10:20 AM
quik2kSi
Jul 25, 2003 09:07 AM
PYITR821
Jan 16, 2003 06:32 PM
