How do you know you've gotten water in the cylinders?
Old Jul 5, 2007 | 10:16 PM
no1knows908's Avatar
Default How do you know you've gotten water in the cylinders?
So earlier it was raining real bad and I to run to the store for something. Well on my way home theres this area on the highway that puddles real deep (about a half of foot all the way across the highway). It had stopped raining for a while so I figured it had dried up. Well I was driving home and I didn't notice the puddle till it was too late and SPLASH. I hit it hard but the car never killed so I slowly drove through it. Well a few seconds down the road it started bogging down real bad and popping like it was missing on one cylinder. I wasn't far from home so I drove the rest of the way. Well I turn on to my street and it starts to barely move. I had it floored and it was only at about 2,000rpms and then it killed. I turned the key back to the off position and tried to start it again but all it would do is turn over. I turned it over a few times while giving it some gas and it did nothing but pop a few times. I'm hoping a I just fouled the plugs and flooded the cylinder with gas, so I'm going to change the plugs tomorrow morning. And if it makes any difference, I have a 92 Si H23 with a SHORT ram intake and not cold air.
Old Jul 5, 2007 | 10:29 PM
Hawkze_2.3's Avatar
Default Re: How do you know you've gotten water in the cylinders? (no1knows908)
You can pull the spark plugs and get a rag in there to check for water...also pull your look at your wires while they're off and see if there's any water seeping through the rubber grommets.
Old Jul 5, 2007 | 10:33 PM
Default Re: How do you know you've gotten water in the cylinders? (Hawkze_2.3)
Well I was in a real hurry to get to a party so I pulled all the spark plug boots out and there was no water above the plugs. Thats was the first thing I checked because it misfired real bad once when I degrease the engine and water got under the boot. I made sure none of the plug wires were disconnected. Is the easiest way to drain the cylinders just to pull all the plugs out and turn it over with a tower over the valve cover? Or should I pull the fuel pump relay and turn it a few times?
Modified by no1knows908 at 11:44 PM 7/5/2007
$amGD3
Jan 12, 2015 04:44 AM
japspecjohn
Dec 9, 2003 07:03 AM
quikB18B
Sep 4, 2002 09:45 PM
