CEL #42 oxygen sensor heater.??what and were is it>??
Old Jul 5, 2007 | 03:06 PM
mustang5.slow's Avatar
* B A N N E D *
Default CEL #42 oxygen sensor heater.??what and were is it>??
ok i don't understand what i need to do for this... the oxygen sensor heater. what is it how do i fix it
i searched and found one other topic such as this. but my o2 plug only consists of one wire.??? how do i fix this is it another plug i should be looking at.??
Old Jul 5, 2007 | 03:26 PM
Donkey85's Avatar
Default Re: CEL #42 oxygen sensor heater.??what and were is it>?? (mustang5.slow)
that is actually part of thee o2 sensor. a heated o2 sensor is usually a 4 wire unit.
now if you only have a 1 wire o2 sensor that is a non heated unit and is heated up by the exhaust. hope that helps
Old Jul 5, 2007 | 04:18 PM
thesmogman's Avatar
Please give us the year of car and the year of the motor. It will help us help you.
Heated O2 sensors have either 4 or 5 wires. Usually OBDII.
All it does is heat the O2 sensors, so it will start to respond to the exhaust faster. This in-turn let's the ECU get into closed loop(Working off the sensors)faster. All to lower emissions sooner.
Should be in the exhaust somewhere. Some are in the Manifold or piping, some are on the cat.
You might have two also. One before the cat and one after it.
Old Jul 9, 2007 | 02:06 PM
* B A N N E D *
Default Re: CEL #42 oxygen sensor heater.??what and were is it>?? (thesmogman)
well i just figured this out the CEL42 only comes on when i have the p75(LS) ECU
and when I have the P06(single cam)ECU the CEL42 doesn't come on... should i worry about this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">Please give us the year of car and the year of the motor. It will help us help you.
my car................92'
Engine................96' B20B
ECU...................P75
BTW thanks guys.
Old Jul 17, 2007 | 10:30 AM
* B A N N E D *
bump for my last post
Old Jul 17, 2007 | 12:26 PM
Relic1's Avatar
you have a P75 with a one wire O2? you will have a CEL because you don't have an O2 heater.
a P06 should set the CEL also... is it chipped?
you need a four wire O2, or to chip the ECU and disable the O2 heater.
Old Jul 18, 2007 | 08:56 AM
* B A N N E D *
Default Re: (Relic1)
cool but will it effect my fuel economy???
Old Jul 18, 2007 | 09:32 AM
Relic1's Avatar
yes, having the CEL on will drop your mpg.
sully3275
Aug 8, 2013 08:53 PM
'96typeR
15
May 17, 2008 11:13 AM
quik89
Jul 24, 2004 03:40 PM
djnikko
Sep 8, 2003 12:44 AM
