pressure relief valves
Old Jul 5, 2007 | 01:18 PM
nonvteclude's Avatar
Default pressure relief valves
i searched around but only found one thread. how many of you guys are running them? i understand what they do but are they really that helpful? and final question if these really do help where do they actually get hooked up?
Old Jul 5, 2007 | 03:02 PM
NJIN BUILDR's Avatar
Default Re: pressure relief valves (nonvteclude)
Do you mean a bov or wastegate maybe?
Old Jul 5, 2007 | 03:49 PM
Default Re: pressure relief valves (NJIN BUILDR)
no its a relief valve. greddy makes one. from what i understand it is there in case a boost spike happens and it relieves that pressure over the set boost level
Old Jul 5, 2007 | 03:51 PM
Jared's Avatar
i always setup a boost cut in the ems.
Old Jul 5, 2007 | 09:11 PM
Default Re: (Jared)
does that prevent boost spike from getting to the motor?
Old Jul 5, 2007 | 10:22 PM
HiProfile's Avatar
Default Re: (nonvteclude)
A pressure relief valve is AKA a pop-off valve. It opens at a pre-set psi, and doesn't close until it 'reads' zero psi. Most EMS's aren't as flexable as the ones Hondas can use, and this was usually for older cars that used the factory ECU.
I always make the 'overboost' ignition columns (tapering down to) -6 degrees. I can tell you for sure that -6 degrees of timing under 10psi of boost will not let your motor rev. Even if it does (say a 3.0L with a GT42), you WILL notice something going on... Essentially it feels like a rev limiter, except its not like most boost cuts that cut fuel.
Cutting spark would be ****, but the EMS's that do cost more than I'm willing to pay. IGN cut can be harmful to your turbo and exh valves (only if done for long periods), and to be honest I'd rather burn out a turbo than wash out my rings.
Jared
Feb 27, 2006 07:25 PM
_Endless_
Dec 17, 2002 10:57 PM
TheIntegraGuy
Nov 18, 2002 08:35 AM
Duck Sauce
Aug 10, 2002 08:00 PM
boostn5Ghaba
Jul 19, 2001 09:34 PM
