intermediate shaft
Old Jul 5, 2007 | 08:08 AM
hitekper4mance's Avatar
Default intermediate shaft
What would cause an intermediate shaft to break?? I have recently discovered that the shaft completely broke in two pieces. I didnt realize the problem I had with the car not driving was the shaft because it broke behind behind the plate that covers the transmission opening. I guess kind of like the metal dust cover. I'll post a pic when I get a camera. I cant do anything except to replace it but... I just want to know what would have been the cause. Thanks.
Old Jul 5, 2007 | 02:57 PM
NJIN BUILDR's Avatar
Default Re: intermediate shaft (hitekper4mance)
Never seen or heard of any one breaking an oem one.Even people making big power just use the stock ones.There are some aftermarket ones out there and I don't know the quality of those.
Old Jul 5, 2007 | 03:56 PM
Default Re: intermediate shaft (NJIN BUILDR)
lol. well, you'll get to see where it broke and see how clean it snapped when I get a hold of a camera.
I am kind of dumbfounded on it. That is why I posted this question. I would assume that I would have bent or twisted an axle before breaking this shaft.
Like I was saying earlier also, the only thing I can do is replace it, which isnt a problem but, curiousity kills. I'd really like to know what would have cause it to break all the way through.
Old Jul 6, 2007 | 12:33 PM
Old Jul 6, 2007 | 02:33 PM
sackdz's Avatar
wowzah!
Old Jul 6, 2007 | 04:04 PM
Default Re: intermediate shaft (sackdz)
i would think that I would have spun a gear, broke a cv joint or even twist the axle before I would have snapped that shaft. Of course after I pulled it out of the car, I thought, maybe the shop that put the engine back together put in one that was already damaged. I see some writing on it DC2 so it obviously came from a junk yard or something. Makes me wonder what happened to my original one.
EITHER WAY, what would have caused it to snap, assuming that it was a good shaft and not cracked or damaged before installation.
Old Jul 6, 2007 | 06:25 PM
sackdz's Avatar
i would say nothing short of a manufacturing defect
Old Jul 6, 2007 | 06:46 PM
If it came out of a wreck it may have been already hurt.I have gotten a couple of ls engines that had the snout of the crank bent but the pulleys were fine.
Old Jul 6, 2007 | 08:03 PM
builthatch's Avatar
MiG-21 superfan
ive researched ALOT about intermediate shafts and the worst i've ever seen one get hurt is bearing damage.
that is highly unusual. think about it- it's supported on one end by a bracket, so for that end that goes into the diff to see any strange angles is nearly impossible.
at any rate-
Yonaka makes an 'all-new' intermediate shaft, it's the only aftermarket one i'm aware of, and it's very nice. it's 109 + ship from streetimports.com and is IDENTICAL to a new factory one. i bought a new seal, bearing and circlips from honda to rebuild a factory one i had and the seal has the same numbers on it that the yonaka one has and the support has the same numbers cast into it as well.
Old Jul 7, 2007 | 08:30 AM
Default Re: intermediate shaft (builthatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch &raquo;</TD></TR><TR><TD CLASS="quote">ive researched ALOT about intermediate shafts and the worst i've ever seen one get hurt is bearing damage.
at any rate-
Thanks for the info. I still cant see how it would have happened other than it was damaged previously. The shop that built the engine put it all together and I see that they didnt use my old one, who knows why they didnt. Probably lost it and had to replace it. Even still, piece is solid.
I'm gonna try another factory one and if that fails.... holy ish.... dont know what I'll do but, I'll keep that aftermarket one in mind cause its not easy to find these shafts.
BTW, if ya read this again....you ever get the vibrations out of your ride??
Old Jul 7, 2007 | 08:52 AM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitekper4mance &raquo;</TD></TR><TR><TD CLASS="quote">
BTW, if ya read this again....you ever get the vibrations out of your ride?? </TD></TR></TABLE>
haha, nope! i have a new trans being shipped next week from HMO, hope to have it in on the 18th or so. i can't believe it's still doing it man...
i am just hoping it's the diff, which sounds crazy, but if it's not, i dunno what to do!
http://members.aol.com/builthatch609/carprob.doc
B_Swapped93
Oct 28, 2013 01:38 AM
Dragmania
May 28, 2011 03:57 PM
ge_itr
Feb 3, 2007 07:27 PM
compprat
Honda Civic (2001 - 2005)
Jul 16, 2006 06:40 AM
Cheeech
20
Dec 22, 2005 05:55 PM
