Motor swap
Old Jul 5, 2007 | 07:45 AM
1.6vx's Avatar
Default Motor swap
i have a 99 civic EX. I"m dropping a b16a2 motor in to my car is all the wiring the same or do i need a SI wiring harness i know i need the ECU witch i have already but other than that anything else i need to take car of.
Another question is the 99 Ex ecu the same as 96-98 EX
Old Jul 5, 2007 | 07:47 AM
cb07's Avatar
Me first, me first!
Search.
/I win
Old Jul 5, 2007 | 07:50 AM
Boost_V's Avatar
Default Re: (cb07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb07 &raquo;</TD></TR><TR><TD CLASS="quote">Me first, me first!
Search.
/I win</TD></TR></TABLE>
show us your results
Old Jul 5, 2007 | 07:54 AM
1.6vx's Avatar
ok i did no luck too stupid any help.
Old Jul 5, 2007 | 07:55 AM
redhatch8u-up's Avatar
Default Re: Motor swap (1.6vx)
for those of us that dont mind answering questions, you can use the ex harness you may have to extend some wires. A 96-98 ecu is obd2a a 99-00ex ecu is obd2b. there is a difference in the plug ins and what not. You may want to switch to obd1 via a jumper harness for more options with ecus if not then a pct civic type-r ecu, itr ecu, and a us spec si ecu are your options running dual cam setup
Old Jul 5, 2007 | 09:10 AM
perseverance's Avatar
b16a2 and d16y8 out of 99ex are both obd2b. u can use a p2t ecu like u said u already have. i wouldn't go obd1 unless you're planning on retuning it or going turbo. if you plan on running stock then stay ob2b.
Old Jul 6, 2007 | 01:22 PM
1.6vx's Avatar
good info guys. I just plan to stay stock and IM legal
Supa_Slow_Civic
Jan 20, 2005 02:54 PM
b1698civicex
Jan 26, 2004 02:33 PM
ITR#465
May 2, 2003 06:21 PM
madtownhonda
Jul 3, 2002 09:23 AM
enthusiast128
Nov 18, 2001 07:52 PM
