Honda CRV Fuel pump Location....
Old Jul 5, 2007 | 06:06 AM
KevronsEG's Avatar
Default Honda CRV Fuel pump Location....
Hey guys thanks for reading my post. I'm trying to help my dads friend who has a 1998 crv. I have never owned or worked on one before, just civic, integra's and so on. I know the civic's you can get to the fuel pump from under the rear seat. No dropping the tank to get to it. I was wondering if CRV's are the same way. I tried to search and i get nothing.
Thanks guys Any info whould be great.
Kevin
Old Jul 6, 2007 | 08:33 AM
92_civic's Avatar
Default Re: Honda CRV Fuel pump Location.... (KevronsEG)
1. Fold the left rear seat cushion forward, and remove the base frame cover.
2. Remove the access panel from the floor.
3. Relieve the fuel pressure.
4. Disconnect the fuel lines.
5. Disconnect the 5P connector from the fuel pump.
6. Remove the fuel pump mounting nuts.
7. Remove the fuel pump from the fuel tank.
8. Install the fuel pump in the reverse order of removal.
should get you where you need to be
Old Jul 6, 2007 | 02:47 PM
KevronsEG's Avatar
Default Re: Honda CRV Fuel pump Location.... (92_civic)
Thanks. I was trying find out if i had to drop the tank or i could go from under the seat. I did find a autozone manual just a bit ago and also found its under the seat. Thanks for your response.
Kevin
hamizle
Aug 17, 2009 02:38 PM
mitchell_2kSiR
Jun 9, 2008 12:36 PM
jskord
Jan 24, 2008 06:42 AM
birds_sol_94
14
Aug 10, 2004 01:15 PM
Ragezero76
Jul 19, 2004 05:09 PM
