what header is good for a blower besides kamikaze?
Old Jul 4, 2007 | 09:17 PM
Black R's Avatar
25 Year Member
Default what header is good for a blower besides kamikaze?
i've got a 98 itr here at the house (wifey's) that has a vortech blower and kamikaze header. The welds at the flange to the head are cracked on ports 2 and 3. So I need to pull it and have it (hopefully) rewelded.
Is there another header that's good for use with a blower, that maybe doesn't have such shitty build quality? This is her daily driver and little issues like this are just a pita!
Old Jul 5, 2007 | 09:38 AM
rmcdaniels's Avatar
Default Re: what header is good for a blower besides kamikaze? (Black R)
Just get something with a big collector. Most quality headers out there are made for NA, so they will be optimized for velocity to enhance scavenging. Most header builders design and build for this effect, which is very important to a NA motor. For a SC'd motor, you want something big and unrestricted, the blower will take care of charging the cylinders.
I had one custom made by a welder at a local shop, using a $83.50 merge collector ( http://www.headermania.com/mm5...RSPMC ) with big/short primaries to a 3" collector to a full 3" exhaust. I made 275 WHP at around 6.5 PSI from my JRSC, so I guess it worked okay.
The welder welded it from mild steel tubing, so it was inexpensive and the workmanship is as good as my local welder (which is pretty good). I had it sandblasted and did a DIY ceramic coating to cut down on heat and prevent rust.
Here are some pics:
Old Jul 5, 2007 | 09:42 AM
Bailhatch's Avatar
Default Re: what header is good for a blower besides kamikaze? (rmcdaniels)
that's great
tofu-eg
95
Jul 23, 2009 08:57 PM
VTECth1s
Sep 16, 2006 10:12 AM
MKIIISupra
Sep 8, 2005 03:11 AM
blu3g
May 25, 2005 02:26 PM
DubyaAye
Nov 13, 2003 04:56 AM
