Before I do Clutch work (advice)
Old Jul 4, 2007 | 04:47 PM
devgon2's Avatar
Default Before I do Clutch work (advice)
OK so whoever read my previous thread about some rattling noise coming from font end which kinda sounds like metal clunking. It turns out to be either release bearing or pressure plate related problem.
The reason why I say that because the rattling only happens when the clutch is engaged. Meaning I can rev the engine as much I like in neutral and not hear any rattling. But as soon as I put in gear and rev, you could hear the rattling.
Anyways, the clutch was done about 5k miles (7000 KM). What I wanna know is should i replace the whole clutch or fix the bearing/pressure plate problem??
Also, I will be doing this by myself. I'm noob but if I have the service manual in front of me, then I don't think it will be that hard.
Any advice and special tools that I would need??? I will be doing this next week....so suggestions and advice are welcome...
thnx
Old Jul 7, 2007 | 09:57 AM
SikB's Avatar
Default Re: Before I do Clutch work (devgon2)
Well if you are going to take the preasure plate off you will need clutch alignment shaft, torque wrench and a set of 12 point sockets.
Old Jul 7, 2007 | 07:40 PM
M2B4's Avatar
Default Re: Before I do Clutch work (SikB)
i dont have much advice, but i just ordered my exedy stage 2 and ive never done a clutch job so come back and inform me on how it went for you bc im about to do it my self u can be my guinea pig
Zteve
Nov 18, 2009 08:46 AM
kelley_james
Oct 22, 2007 07:14 PM
typicalfbodydriver
Dec 18, 2005 02:04 PM
PoWeRBaN_PaNdA
Nov 29, 2005 05:10 PM
ludelvr
Sep 28, 2003 11:02 AM
