HEEEEEELP!!! y8 mani on dm d15b please ASAP
ok... well the coolant line on thr y8 is a circle & the one on the d15b is in a pentagon shape. not i have the y8 mani gasket... would this work?
Use the y8 gasket, you'll be fine. I've done this many of times. As for the injectors? I don't know, try using the gaskets out of the d15 mani.
you use the z6 gasket, since the d15b has a z6 head. as far as the injector washers which ones are you using? i think you need to use the ones out of the y8, also on some injectors they have spacers that sometime need to be taken out for the injectors to fit properly
here... http://www.geocities.com/joeyp....html
i am using the one off of my jdm d15b & bending it instead of 90*... to 45*
jyacoba2009
21
Oct 7, 2009 05:29 PM
CaptinMcnut
Nov 22, 2004 09:08 AM
