Oil out of breather filter
Old Jul 3, 2007 | 06:50 PM
plonger's Avatar
Default Oil out of breather filter
Hello my car started to shot oil when in boost from the breather filter of my catch can ....
So i did a compression test and all four cylinders --->190 psi
What can do that without loosing compression ?
The setup is :
5-6000km since rebuilt B18c1 81,5mm pr4 pistons 9:1 compression
Stock rod
turbo t3/t04e 57 trim at 13 psi
The car never ran lean on the wideband or what ever ....
Old Jul 3, 2007 | 06:53 PM
bigbadboy's Avatar
well thats wat is called blow by. usually if you don't have a catch can thats returns the oil the motor, the catch can fills up. so if you don't have a return line it then i would check the catch can every so often and empty it. also keep an eye on your oil level.
Old Jul 3, 2007 | 06:59 PM
plonger's Avatar
Default Re: (bigbadboy)
Well yes the catch can fills up... then i drain it weekly but normally before it wasn't blowing oil from the filter of the catch can
Old Jul 3, 2007 | 07:08 PM
plonger's Avatar
Default Re: (Mr Wonderfull)
But if it were the rings or ringland it's not supposed to have low compression test result ?
Old Jul 5, 2007 | 01:00 PM
plonger's Avatar
leakdown test result :
Cyl1 :5% loss
Cyl2 :10%loss
Cyl3 :10%loss
Cyl4 :5%loss
That's not that much so still rings or ringlands ?
Old Jul 5, 2007 | 02:59 PM
plonger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull &raquo;</TD></TR><TR><TD CLASS="quote">hmmmmmmmmm......</TD></TR></TABLE>
What do you mean ?
fernando.
13
Jul 7, 2009 01:33 PM
DarkDragon
Oct 28, 2005 04:15 PM
boostismycrack
Feb 13, 2005 07:29 PM
B18C1 '96 Coupe
Apr 28, 2003 06:58 AM
