Oil out of breather filter
Hello my car started to shot oil when in boost from the breather filter of my catch can ....
So i did a compression test and all four cylinders --->190 psi
What can do that without loosing compression ?
The setup is :
5-6000km since rebuilt B18c1 81,5mm pr4 pistons 9:1 compression
Stock rod
turbo t3/t04e 57 trim at 13 psi
The car never ran lean on the wideband or what ever ....
The setup is :
Stock rod
well thats wat is called blow by. usually if you don't have a catch can thats returns the oil the motor, the catch can fills up. so if you don't have a return line it then i would check the catch can every so often and empty it. also keep an eye on your oil level.
Re: (Mr Wonderfull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull »</TD></TR><TR><TD CLASS="quote">hmmmmmmmmm......</TD></TR></TABLE>
What do you mean ?
What do you mean ?
fernando.
13
07-07-2009 01:33 PM
boostismycrack
02-13-2005 07:29 PM
